Originally Posted by Mark Seaton
Hi Guys,
Thank you for all of the interest. I will have another small batch of subs available in January, and then stock will catch up mid-late February I won't be able to firm up dates for availability in February until after the new year.
I plan to work through the PM and e-mail inquiries this weekend and early next week inbetween holiday obligations. Thank you for your patience.
Best Regards,
Hi Guys,
Best Regards,
Mark do you know when you will have your web site up and running.
Allen
......unfortunately, as it is well documented, Cold weather is my Kryptonite!
What I did do a little different is push the outer two subwoofers away from the center more than the previous subwoofers were. The measurements co-incided with my earlier findings that there was a very small improvement above 50Hz with nothing else lost. With the great results we have had, I am only mildly curious to experiment with pushing two of the subs into the front corners I somewhat expect to find other problems creeping in over the ranges that are behaving so well right now.
