AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Seaton Sound SubMersive1
Seaton Sound SubMersive1 - Page 161
post #4801 of 8164
Marks forum has the following posted:
The following are currently available products:
All orders include 5.1 Audio Toolkit DVD. Limit one per customer.
http://www.seaton-sound-forum.com/post?id=3364736
I added the emphasis. I'm not sure why some Submersive owners are saying they didn't get one, but I suggest you contact Seaton Sound.
Craig
post #4802 of 8164
Craig (John)[/quote]
Craig
We are waiting on a bulk of the DVD's to arrive. We will be shipping the AudioToolkit DVD out as soon as those arrive. I should have confirmation of when in the next few days. Obviously we didn't want to hold up SubMersive shipments just for the DVD.
post #4803 of 8164
Excellent! Thanks Mark.
post #4804 of 8164
Craig,
I completely agree with you. Adding more high amperage circuits makes the most sense, and would likely be the best solution to the problem. However, Mike's room is on the 2nd floor of his parent's house. The electrical service comes in through the basement. To get more 15 or 20 amp circuits up to his room would require some fairly extensive re-wiring that would impact his parent's house, (i.e., running wiring through multiple floors with the concomitant cuts and patches in drywall, along with repainting.) Even if Mike could pay for it, I'm not sure his parents would support it.
Given the current, (PI) limitations, I think his best bet is to limit any "outside" current use and to maximise the current availability to his HT system.
Craig (John)
Note I didn't say there wasn't enough circuit capacity, but that there might have been enough Voltage drop to cause an issue. Of course now that I had more time to check with Mike and dig a bit further, I suspect this is a DC protection induced from Audyssey EQ and something going on in the signal chain. I was involved in some pre-production changes to keep this from happening with the amp on home theater systems, but it's certainly possible that a unique case could trigger it. No other users have induced this yet, but it can certainly be further adjusted if needed.
post #4805 of 8164
Yea, I'm good at finding stuff like that. I will try some tests when I have the time. But for now, I will just watch my finger on the remote. Since this is the only time it has happened, I don't think it's a wide spread issue for me.
post #4806 of 8164
Hey Mike,
glad to hear. I have certainly tried to reproduce it here with my pair plugged into a 15amp circuit. No luck. This circuit has PJ + Subs and at least 10 lights on it. Our 1953 house has something wrong with the wiring and basically turning on anything that has any load at all even a small fan will cause the voltage to sag. In my computer room all the UPS's kick on all the time when the laser printer warms up. Fortunately for me no issues. Even at reference levels with the pair of HP's I have no strangeness.
Hopefully you've been watching lots of movies.
repo-men and ironman2 (finally) showed up from netflix today
Sean
post #4807 of 8164
Thanks for that Sean. In my room the biggies are my Bryston amps(specs on previous page), which are NOT green, and the new submersive amp.
I think it's OK if I say what my plan is. First off, through discussions we may have a theory. What I am going to do is the following. Again, only WOTW regular DVD has done this. All other movies regular and BR are fine. So the plan is this. First, run the movie with my full system at -10db. This is the level that "tripped" the amp. So that is first and I will see what happens. Then I will run the system with one of my amps off and see what happens. Finally, I will disable Audyssey and run the movie and see what happens. If it turns out to be Audyssey, which I hope it is, I don't know what I could do. But I will cross that bridge when I get to it. In the mean time I am still enjoying movies and music very much.
post #4808 of 8164
So I just got a new Marantz AV-7005 to replace my 3808 about a month ago. Since then, my Sub has been nearly unusable. It sounds terrible and muddy. I played with Audyssey multiple times, changed speakers to different settings, messed with the crossovers...nothing. I actually also found out that turning the volume knob on the sub did nothing, whether max or at 0 it played the same volume.
Next thing I will do is pull it away from the corner a bit, but its just way too overbearing for my system at this point and I cant seem to dial it down.
post #4809 of 8164
I think you need to get in touch with Mark as this isn't normal. On my SubMersives dialing all the way down to -36 dB makes them near inaudible. Dialing the trim to 0dB would produce a massive amount of bass. Either way would be way more than the +/- 12 dB Audyessey could compensate for.
What does Audyssey set your sub trim set to in your pre/pro after you run it?
post #4810 of 8164
Quick follow up to what we did figure out...
The shut down in fact had no relation to power. In fact it was a DC protection cut out which we believe to be related to some Audyssey mis-behavior with the EQ applied. The cut out does not occur with Audyssey turned off. When we found this problem and Craig had noted that they had to turn the SubMersive's level way down I suspected the process was getting thrown off by a big peak in the response skewing the starting levels, so I dug up my no EQ measurement of Mike's room. Sure enough...
While I'm sure the room treatment efforts might have smoothed some ripples, I'm sure it had little effect on that 15dB mountain at 45Hz. I expect a simple solution of re-running Audyssey with the SubMersive HP turned up 10-15dB louder on its volume dial.
The levels were set using a level meter with a noise test, which would be dominated by the peak, leaving the rest of the range rather low, and possibly prompting Audyssey to boost much of the range, especially down low. I suspect some digital or analog clipping is causing the problem at very low frequencies. Raising the starting level should cause Audyssey to attack the peak and not boost do so much boosting down low.
post #4811 of 8164
Thanks for that post Mark. I did not know you still had a pre eq chart from that long ago. That peak is simply insane.
post #4812 of 8164
Hi HyperM3,
I recall a message you had sent about the system sounding muddy at some point, but not the correlation to the new preamp, and especially not the problem related to no change from the volume dial. When the dial is full counter-clockwise (negative infinity symbol), it should be muted with no output. It sounds like something is misbehaving or not functioning properly in the system. Please give us an e-mail or a call to help troubleshooting and zeroing in on the source of the problem.
post #4813 of 8164
Lowering the sub's gain and re-running Audyssey setup will simply make the receiver/processor compensate by trimming the channel by an additional 10-15dB. Since Mike's trim is already at -12dB and max trim is -15dB, that will result in the receiver/processor being unable to balance the channels and the sub channel being w-a-y too loud.
Are you saying Audyssey is causing the 15dB peak? Or boosting everything else because it couldn't scrub 15dB off the peak?
post #4814 of 8164
Hi HyperM3,
Ok, Im an idiot. I didnt realize it was -36. I thought 0 was the lowest setting. I had it usually set between 6-8 thinking that was a low setting. Well, after playing around with it in the 20 range everything sounded pretty sweet and smooth. Thank you for both the quick responses.
post #4815 of 8164
I believe so. Is 105.7 dB a lot for a sub?
post #4816 of 8164
If Audyssey boosted everything else to match the peak ... instead of cutting it, then the corresponding channel level should be lower. Seems to me that it would all wash out ...
post #4817 of 8164
Not a Seaton Submersive with the new amp!
post #4818 of 8164
Hard to believe Audyssey's algorithm includes such a scenario.
post #4819 of 8164
A scenario with a response that is "mostly" flat but with a broad 15dB hump?
post #4820 of 8164
No a scenario that would raise much of everything else instead of dealing with a peak/bump within its limits.
post #4821 of 8164
The graph Mark posted was from 2 years ago when Mike had his old Halo and no Audyssey. That was the "raw" response of his room without the DSP-30 in the system. The 45 Hz peak was the inherent resonance in the room.
When I took out Mike's "old" amp it was set at -24. The new amp had to be turned almost all the way down, (-34 on a scale where -36 is the lowest setting), to measure -83 dB on the opening screen of Audyssey XT32, (where it tells you to set the level to 75 dB.) Even at it that low setting Audyssey still set the subwoofer trim at -12. I assumed the issue here was that the sub is corner-loaded in a very small room and the listening/measuring position is only about 2 ft. from the sub. With all those factors combined, I figured Mike was getting *huge* room reinforcement of the level, and that was what was causing the settings to be turned down so low.
Mark, I don't see how turning the sub gain up will keep the sub in the range allowed for Audyssey/Integra's trim setting. I suppose it could be set to -32, which should then result in a -14 trim setting. Beyond that, I think you get outside the pre/pro's trim range.
Or, are you speculating that Audyssey's EQ will knock down that big peak at 45 Hz and get the level closer to the "expected" level, and get it in range? If so, I'm not sure that will work. Audyssey doesn't go back and re-ping the speakers after the EQ is set to see if the levels have been impacted. It could be done afterwards with an SPL meter, but it wouldn't be done by Audyssey.
Thoughts?
Craig
post #4822 of 8164
Hi prepar,
No, the measurement was of the raw SubMersive in-room with no EQ. That is an approximation of what Audyssey is getting as input to work with. Lowering the sub's gain won't help, and would probably make the problem worse if it is the problem I believe it is (can't be 100% sure yet).
The SubMersive's level needs to be RAISED, not lowered, so the area outside of the peak is at the average level. Exactly how and the order in which the level setting and response correction is handled becomes critical for an automated system with this process, and I do not know the exact process Audyssey uses.
Interestingly, this could very easily explain some of the odd subwoofer level settings I've observed after running Audyssey. Since the system never measures the acoustic response after correction, there is only so much they can do here.
post #4823 of 8164
Thoughts?
Craig
The only hurdle I see is if Audyssey will let you run with the level set higher. Really the level should probably be around -24dB on the dial. The problem is that an SPL meter type level adjustment will be dominated by the peak and leave the rest of the response set low. I suspect if I eventually get out there or if Mike can have someone use a pro kit or just display the subwoofer correction graphs we could tell a lot. The other test we should have Mike do is play the WOTW scene at -10dB on the main volume with Audyssey turned off and raise the level of the subwoofer by 10dB to determine if the protection is from the recorded content or by something in the Integra's chain being clipped or over-driven.
My suspicion described above basically revolves around how much of the Audyssey measured response is above the target level vs. below it. If it is pulling up the response that is below the line, this would solve the problem. This also might be related to very low frequency content which is still high enough in level to try and correct, where raising the level will keep from boosting the signal as much. Unknowns until some further tinkering is done.
post #4824 of 8164
For reference mine is corner loaded in an enclosed 12x23x8 room, 11 feet from LP . My amp level is 2 notches from off (whatever level that is). Even then the SVS Sub EQ measured it way high. Then MultEQ XT brought it back down to +9dB (still high but within acceptable range).
If the sub is indeed 2 feet from the main LP you may need to find another place for it.
post #4825 of 8164
There is no other place for it. Mike's room is not large enough to allow *any* other placement.
Craig
post #4826 of 8164
Then perhaps the smaller amp.
post #4827 of 8164
Maybe I will try to get back up there soon and rerun the calibration and Audyssey. If I can't, maybe Jeff can run up there with me after the holidays and measure with his Pro Kit.
If I get up there, would it be helpful to run close-mic'd graphs with Audyssey on and off to see what Audyssey is doing?
Craig
post #4828 of 8164
Hi prepar,
I guess that would fall to the system owner or their "assistants" to look at post-correction measurements. In trying to troubleshoot Mike's system, a post-correction measurement would be helpful, and I doubt that it would show the big hump. If that speculation is correct, then what *could* be causing the protection circuit to activate?
Jeff (pepar )
post #4829 of 8164
If there is a performance reason why the gain should be higher, then an inline attenuator can be used to pad down the input signal allowing the gain to be raised ....
post #4830 of 8164
Jeff (pepar )
Post-correction measurement:
That's Prg 1 and Prg 2 measured at the LP.
Craig
