Agreed, and much too early to be speculating about ... mis-behavior, n'est-ce pas?
) The bass with so incredibly loud that I was afraid we were going to blow the sub. It seemed like it was at least 20 dB louder than the speakers. Therefore, I was not the least bit surprised when we had to turn it down considerably to get it even close to being in range. And because we were still "above range" before the Audyssey run, I was even less surprised when the post-Audyssey trim setting was deeply negative, (-12).
I usually listen to movies between 9 to 16 below reference. My SubMersive HP, 50inch Plasma, BR Player, Ps3, Lights, Fan, Onkyo 805 Receiver, HD-dvd player and Dvr cable box are all plugged into the same 15amp breaker with no issues.
Hi Mark,
This is exactly what I encountered when using Audyssey. The graph below shows: 1) The bottom of the graph shows the measurement at the LP, before and after Audyssey. Although the response shows the peak was flattened, the sub was suddenly (and unexpectedly) running very hot, with considerable boost across the entire sub BW. 2) The traces at the top of the graph are close-mic. You can see that, instead of pulling down the peak, Audyssey boosted either side of the peak. The purple trace is the close-mic without Audyssey and the green trace is what Audyssey did to smooth the response: ![]() The result was a +7dB bump in SW level. Had I been watching a movie like WOTW at reference level, or with the SW level running hot to begin with, it would have been somewhat noticeable. ![]() Bosso. |
| If I get up there, would it be helpful to run close-mic'd graphs with Audyssey on and off to see what Audyssey is doing? |
Knowing the response and that the -34dB Volume knob setting on the SubMersive was showing 80-83dB at zero dB, the -12dB setting indicates to me that the magnitude correction applied by Audyssey included significant gain on either side of the peak to smooth the response, and it is the gain applied behind the scenes that I am suspect of.
Hi Mark,
I'm thinking very seriously of buying a Submersive, and have been reading this thread extensively doing background research.
All this talk of Audyssey and room EQ and MikeDuke's problems has got me a bit spooked I'll have to say. I wonder, does anyone have experience with Submersive and Yamaha amps? I have an RXV1700 with YAPO (Yamaha's version of room EQ). Should I expect that this will work similarly to Audyssey? My room is 3000 cf, with a 5' arch to more area (say another 1600cf). It has wood floor and no acoustic treatments. I will be colocating the sub behind one of the mains next to the entertainment unit near the arch. The sub will be about 12 feet from the main listening area. I know nobody can predict room response, but should I expect to get a good outcome with the Submersive in such an environment with only the Yamaha YAPO EQ to help me dial it in (e.g. no pro install)? |
Am I correct in assuming a single Submersive HP is not too large for this room?
Any suggestions of other tools I might use to setup the system. I have no end of computers around. Any software that might work. What makes all those pretty graphs everyone posts? Is that an output of Audyssey?
. BTW it is not an overall problem. I have watched many BR and regular DVD's. WOTW is THE ONLY movie to do this. Please don't let that one time event prevent you from getting this fantastic sub.
________ _____________________ ____________ | Arch | | | | Door | | |Sub | |_ E.Unit___| | | |F| |F| | | | | | | | | | | | | | | | | | | | | Couch |
