It's not my first choice either. That's not the point. The point is that it is still a very legitimate way to set up a subwoofer, and it can be made to work quite well. Does Mark say *anywhere* that it causes pain, or is absurd or insane? No! He says it's not a "preference." Nonetheless, in some situations, it is the best or only alternative. A thoughtful person optimizes those alternatives as much as possible, which is exactly what Mark did in this situation. It was definitely NOT the "biggest mistake" as you've portrayed it.
Craig
. When Craig and Dennis were kind enough to come over again, and help me change out the amp, we moved the sub out of the corner and about 1/3 up my long wall. That, plus Audyessy and the SMS-1 really made a big difference in my room. So all this B.S of a sub being 2 in from your ear not being able to sound good is just that. B.S. When I had it in the corner, where Mark put it in the first place, I never had any complaints whatsoever from anybody. Now, it is just a bit further away and since Craig helped me out with the Audyessy setup, it sounds even better. So I don't know what else to say about that. If you look back, you will see that not only does my room sound good, as related from the posts by Craig, but it also measures very good.
), at 40 to 45 Hz at your listening position. Here is a measurement I took of that same peak:
