Hey all, Are Tact2 and the Antimode devices meant to be used instead of Audyssey, or in conjunction with it? I'm goiing to start gear I'll need to get the F2's as good as they can get. Having never measured before or independently tuned subwoofers w/o Audyssey or MACC in the early days, this is a completely new arena for me.
Usually you would run any subwoofer eq before Audyessy/ MCACC etc. Get the subwoofers measuring as flat as possible, then run the auto cal.
Here's the best that I can get in my room using Audyessy XT 32 with dual HP's,
. But it could be a situation like that.
