ok, bill, if you don't stop that kind of crazy talk, we are going to come take your subs away from you...
i'm going to have to go with "outies", unless i want to have the manifolds hanging down into my dining room... which actually might make for a good "discussion piece"...
), and carefully following the guides that have been written, and you will be cooking with gas...
On the seventh day, the Lord created subwoofer, and all was good in heaven and on earth.
Oh, wow. Just wow! They arrived at 8.00 this morning, all packaging etc intact. They have been unboxed and put in the HT room, where they sat for a few hours to let the electronics adjust to the temperature indoors (they were very cold on arrival). I have since hooked them up to check they are all OK (they are) and, of course, have had to have a listen, without Audyssey on just to see what real woofage is all about :) Initial impression is this:
I will run Audyssey Pro later, measure, do the sub distance tweak, experiment with XOs etc etc etc and will report back here when they are properly setup, calibrated and giving their best.
For now, wow! WOW!
@Mark - thanks for the help you and Kelly gave in resolving the Customs problem at this end. There was no sensible reason for Customs to hold them back and thankfully, they realised that, costing me just a week's delay in woofage.
@Everyone else - thanks for this thread, for the help and advice it contains, and for the encouragement to do this thing. Two F2s in such a small room. Crazy. Totally crazy. But then, one has to remember: you can never have too much woofage :)
Until later...
