I know ideally you should have a dedicated 20a breaker, but would my current 15a outlet be able to handle the hp amp or would i be tripping the breaker all of the time. i don't listen at reference(usually -10/-15). my add'l equipment is fairly efficient meaning averaging 150 total watts on a normal bases.
If you have a dedicated 15A circuit AND your volume is set below reference (-15 through -10dB as stated above) you shouldn't have an issue with the breaker.
