Buying two SubMersive HP's tomorrow.
Looking for advice...
For optimal setup in this room...
I was thinking of placing the SubMersives in the spots my other subs are located (black boxes at 45 degrees in each corner)
*Leaving the SubMersive amp gain at default on both... Use Program 2 designed for larger rooms and lower htz +/-3db... And just run Audyssey MultEQ XT32...*
Anything else I'm missing or should do first?
I know to check Audyssey after and make sure it's not -15db on the sub, I will play with the volume controls on the HP after temp calibration and try to get the receiver to 0db after calibration..
Mark is only about 90 miles from you. Can you get him to come help you with setup. I know he used to do this for a modest fee. Maybe he still does if it fits his schedule. If you can get him, I'm positive he could tweak a lot more performance out of the subs.
Craig
