Featured Stories
Topics Discussed
- categorySpeaker Systems
Related Forum Threads
- Northeast Speaker Shoot-Out: AVS Members Demo 2-Channel Systems Last post on 4/29/13 at 10:49am in Community News & Polls
- Is there a better value than the pl-89s? Last post on 3/2/13 at 2:50am in Speakers
- Small room speaker purchase advice needed Last post on 3/2/13 at 5:08am in Speakers
- 5k To Spend on 7.1: GoldenEar Technology TritonCinema Two or what else? Last post on 3/2/13 at 6:13am in Speakers
- How to set up Sony BDPS390 with my Polk 3000 Soundbar Last post on 2/25/13 at 10:59am in Blu-ray Players
Seaton Sound SubMersive1 - Page 261
AVS Top Picks
- bsoko2
- Trader Feedback: +2
- offline
- 4,198 Posts. Joined 4/2007
- Select All Posts By This User
- kbarnes701
- Trader Feedback: 0
- offline
- 10,414 Posts. Joined 1/2008
You are not 'taking away the amp power' - you're not changing the 'amp power' at all in fact. The knob on the sub is a gain control not a volume control. It means that the sub amp will still reach its maximum power, but from a smaller input voltage that's all.
- SOWK
- Trader Feedback: +12
- SomeOne Who Knows
- offline
- 3,303 Posts. Joined 12/2004
- SOWK
- SomeOne Who Knows
- offline
Here is how I do mine...
Step 1:
Line back of leather chairs with a fabric to deaden reflections.
Step 2:
Turn off house furnace so there is as little background noise as possible.
Step 3:
Self leveling laser to match "perfect" ear height, per my main speaker (vandersteen's) recommendations
Step 4:
Turn projector to lowest fan noise level
Step 5:
Make sure mic is 6 inches away from back of chair / level / and with tip just touching the laser line.
Step 6:
Get to Audyssey screen that has the button measure on it / leave the room, and close door tight.
Step 7:
Use network wifi iPhone app to hit enter.
Step 8:
Audyssey runs with me outside of room / Wait 5 min / go back in room
Step 9:
Rinse and repeat last 4 steps for the next 7 position measurements.
Step 10:
Save
- Gary J
- calculating status...
- offline
- 7,136 Posts. Joined 3/2000
- bsoko2
- offline
- audioguy
- 16,800 Watts of Fun!
- offline
- 2,589 Posts. Joined 6/2001
Must be like Mother Nature.
The first thing I would do if I were SOWK is invest $15 in a mic stand and NOT use a tripod. Secondly, I would follow that advice on the Auydssey Thread. However, Gary J's objections not-with-standing (NOTE: If you examine his room noted in his signature, he has no passive room treatment, so draw your own conclusions) you can focus more of your measurements around the MLP if you are the primary listener. In some cases (mine for example) the FR is virtually identical anywhere on the row of seats.
But, do EXACTLY what the Thread recommends and you will end up with great results.
PS. Is your room dark brown, black or dark gray? I love it with the splash of red. I am going to paint some of my white surfaces (portions of the ceiling, under the soffit) and do the same thing. Very classy.
Edited by audioguy - 2/11/13 at 1:47pm
- SOWK
- SomeOne Who Knows
- offline
Nothing is "wrong" - except mic on chair... But that's more for wooden floors.
Turning off all background noise and leaving the room are great if you can do it.
And fabric on chairs is to kill off any unwanted reflections... This is not a bad thing. It's not like moving furniture around and is only killing unwanted reflections back into the mic.
To you, some steps my be unnecessary, but they can only help to get a more accurate end result. This is for the anal Audiophiles out there. Not saying everyone has to do the above, but I'm just super anal... Lol.
I would recommend to all to only put mic at ear level using laser levels, some speakers can Change the way they sound with only a few inches above or below the ear height.
Edited by SOWK - 2/11/13 at 1:55pm
Using the tripod stand on the seats is not very reliable. Invest in a decent low profile boom mic stand and you can use it for Audyssey as well as with a mic and some software to optimize your sub locations and overall SQ. Another thing you could do to eliminate the seat back issue is recline the seats since a lot of listeners will probably sit this way during a movie anyway. I would definitely try to determine your personal preference (sitting up or lying down) and run Audyssey at that ear height. Of course, if you split time 50/50 then just average the two. I can't tell you how much it pains me to see this AWESOME setup and not have any idea how your room is affecting the SQ. Based on the pics, you have an ideal setup for some acoustical room treatments (e.g. corner bass traps and first reflection panels at a minimum) so do yourself a favor and get some measuring gear. You'll be glad you did it given how much you've already invested in your setup (in TIME and money).
- SOWK
- SomeOne Who Knows
- offline
I would bet a glass of water would not ripple once during any of the test tones if placed on the chair...
But...
I will probably get the measuring gear and I all ready have bass traps / first refection panels / back of room diffusers .
I would say the only thing I need is to find the most optimal spot for the sub at the moment.
- Gary J
- offline
Off track for this thread but re: "objections", "room treatment" and "focus" measurements you got everything in this sentence wrong.
- ack_bk
- offline
- 8,544 Posts. Joined 1/2007
Seriously man, I would not even bother responding. Nice looking room
- kbarnes701
- offline
Full calibration done!
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10:
Save
A few observations. Not a good idea to have the room in a different state for measuring as it is for listening (eg the fabric covers on the chairs). Bad idea to place the mic stand on the furniture. Very bad idea in fact. Can the surrounds/rear surrounds 'see' the mic? If not, raise the mic above the seat backs. It is more important to have line of sight than to have the mic at ear height if you have to choose. Mic should really be 12 inches from back of seat not 6. In step 8, what is this 'waiting 5 minutes' step for?
If you click the links in my sig, you can read my Audyssey FAQ and 101 for many more useful tips about Audyssey best practice, put together over many months/years from the combined experiences of contributors to the 60,000 post Audyssey thread here.
You have such a potentially wonderful room, it would be a shame to compromise it with less than great Audyssey techniques.
BTW, how is your room acoustically treated and what did you use to determine the type, amount and placement of the treatments? Do you have REW or OmniMic etc?
- SOWK
- SomeOne Who Knows
- offline
Room is flat black.
Edited by SOWK - 2/11/13 at 2:47pm
- kbarnes701
- offline
I've tried all of his stuff and Audyssey layout for mic postions does it the best. Does anybody think that Audyssey hasn't tried all the different ways with mic positions and their recommendation for mic postion is found to yeld the best results. You really can't fool Audyssey to get what you think are good results.
It's important to remember that Audyssey has to give a simple and clear set of instructions that will work for the majority of users, and that they are always conscious of trying to get the best result for a group of listeners. Many of us Audyssey fans in the Audyssey and Pro threads have found better results (based on measurements as well as listening) can be obtained with non-standard mic placement - especially where there is only one listener or where only one listener is 'critical'. In the latter case, a tight 'group' of measurements around the MLP can be beneficial, at the expense of the SQ in other seats.
- kbarnes701
- offline
It's not a great idea to have the mic on the chair - it can be difficult to orientate it exactly vertically, and it is not the most stable platform for measuring. A boom mic stand for less than $30 is a much better tool than a tripod for this purpose. Pop across to the Audyssey thread - there are 60,000 posts of great info there, the most relevant of which are distilled into the FAQ and the 101, along with much advice garnered directly from Audyssey.
It's one way to do it and it does no harm - but it isn't necessary to leave the room and Audyssey tests for ambient noise and if the S/N ratio is poor it raises the level of the test chirps to get well above the noise floor. It does this three times and then craps out with a warning if it cannot get a proper S/N ratio for the test. Bottom line - if the measurements run, the calibration is good.
It is not considered a good thing to have the room in one state for measuring and another for listening. If you measure with the absorbent material in place, you really should listen with it in place. Audyssey will have calibrated taking account of the absorbent material, but it won’t be there when you are listening. There's no need to do t that way - pull the mic 12 inches clear of the back of the chair instead and raise it above the back of the chair if it cannot 'see' the rear surrounds or surrounds.
They are not helping get a 'more accurate' result if the cal is made in circumstances not pertinent when listening though. Or if the mic is not stable enough during measuring. Believe me, you are far from Audyssey-anal (yet) :)
True. Although one would hope the off-axis performance of speakers used by most of those in this thread is rather better than that.
This is way OT for the SubM thread so I won't comment any more on Audyssey here - but you would be very welcome in the Audyssey thread!
- kbarnes701
- offline
What he is after though is a nice sounding room ;)
- SOWK
- SomeOne Who Knows
- offline
Room has treatments:
First and second reflection absorbers with space behind to act as bass traps.
Front of room behind speakers deadened with absorbers and corner bass traps.
Back of room has diffusers.
You will notice I do the measurement in reclined position. And it can "see" all rear channels with ease.
Regarding the fabric on the chairs...
Would it really be better with no fabric and have sronger reflections back into the mic?
- kbarnes701
- offline
+1
- kbarnes701
- offline
Would you like to bring this to the Audyssey thread? I am really conscious of how far OT we are getting.
Briefly, think of the wavelengths of the frequencies likely to reflect off a leather chair...
Sorry SOWK, I was responding on my iPhone and couldn't make out the room treatments. Kudos to you for getting treatments that blend so well. I would agree that finding the optimal sub locations is your primary concern but if you placed these treatments without any measurements (or professional advice) then your secondary concern will be to determine if your investment in treatments is doing what it should to improve your overall SQ.
- ack_bk
- offline
- Crabalocker
- the_real_crab
- offline
- 658 Posts. Joined 8/2010
If your SubM isn't blowing you away, It takes 15 minutes to do the swap test and I bet it will blow you away after a clean swap. This is how it works in my room. I know of at least one person in my power buy group that was less than impressed with the SubM and I'm pretty sure he was running Audyssey as well. It takes 15 minutes to see if it's Audyssey or not. I've got $20 it is.
- audioguy
- offline
I still say Audyssey kills the SubM....try running it on your old sub and then do a clean swap. I have an Omni-mic and the measurements don't show how or why Audyssey kills the SubMersive. The Omni-mic graphs look very similar when I Run Audyssey with the subM when compared to when I run Audyssey with my Ultra and then do a clean swap but the difference in bass are incomparable. Why????
Certainly that may be your results but I have had Audyssey on 4 or 5 different subs and it works great on all of them. And my SubMersives blow me away more than any of them. Weird that you are having that problem.
- bsoko2
- offline
Just because the old sub sounded fine as a new sub in the same position will not always sound better. He needs to move the Submersive to a better place in the room.
- Crabalocker
- the_real_crab
- offline
How does it hurt to give it a try? If his sub setup is having a hard time with Audyssey, like mine did, then maybe this might help....maybe it won't but he'll never know unless he tries it. Again how and why this works for me?????
I promise, this will be my last comment on this subject. I hope you figure it out SOWK, the SubMersive is an awesome sub.
- djbluemax1
- offline
- 1,561 Posts. Joined 10/2004
Just saying Max (djbluemax1), one should use a room analyzing program before implementing <40Hz boosts as experience has shown me, when a boost is implemented, the room's acoustics pivot, like on a sonic axis, minus 3-6dB to the right of the boost. With a boost, it's not just the left end of the graph that's affected by the boost. In other words, it's not zero sum or if you will, there's no free lunch. Unequivocally, I cannot say my experience will be everybody's experience but without a room analyzing program, one won't see this pivot when it happens. The point, boosting the <40Hz content, and reducing the >40Hz content, will change how one perceives their room's acoustics. This phenomenon may be a room specific phenomenon so again, FYI, just saying.
I didn’t see that in my measurements when I took 'before' and 'after' measurements of the difference Pgm2 vs Pgm1 made.
Can you please post your own measurements showing this 'pivot' phenomenon you describe?
Here is mine showing the effect of engaging Pgm2: (Edit - blue line is, obviously, Pgm 2, red line Pgm1)
I can’t find right now the graph showing the entire range up to 20KHz, but you will see from the one above that there is zero effect on the FR above about 45Hz and you can trust me that this zero effect continued all the way to 20KHz (as I would have expected).
I'd be interested to see your own graphs along with any explanation for the phenomenon you are describing. Thanks.
Check out post #5794
Oh, and on another interesting note, the wiring in my house didn't catch fire and burn the house down either.
Max
- kbarnes701
- offline
- Seaton Sound SubMersive1
AVS Top Picks
Recent Discussions
- › Official Panasonic VT60/VT65 Series Discussion Thread [No Street... 4 seconds ago
- › Sherwood R-972 User Thread 1 minute ago
- › New Dune HD Max and HD Smart anticipation thread Q3 2010 1 minute ago
- › Dropbox Killer? (Copy.com) Massive Free space! 1 minute ago
- › Microsoft fires the first shot in the "NEXT" generation.... 1 minute ago
- › Acoustic Transparency of Spandex - The Truth 2 minutes ago
- › The "official" Yamaha RX-V673 thread. 7.2-Channel Network AVR 3 minutes ago
- › SVS PB12NSD vs Mirage S10 3 minutes ago
- › Marantz AV8801 Preamp/Processor Official Owner's thread 3 minutes ago
- › Suggestions For Converting Blu-Ray Discs After Ripping 4 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
