AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Seaton Sound SubMersive1
Seaton Sound SubMersive1 - Page 263
post #7861 of 8069
Originally Posted by JimP View Post
.....and what's going on with decay times.
Yes - important point. FR is only part of the story.
post #7862 of 8069
Originally Posted by JapanDave View Post
What i mean is that even though the response curve may be flat, what did it take to do it? What i mean by that is, in some people's cases(not necessarily the case here) that it can take up a lot of head room to get that response and therefore reducing dynamics. I am no expert so please correct me if I am wrong, but that is the way I understand it. And I am not just talking about audyssey here.
Thanks for the clarification. I guess the headroom is a function of amplifier power. I have always made sure I have more than enough to give me all the headroom I can possibly need - I agree with you that it is important for dynamics in real content. I still can't see though why the OP has two graphs that look all but identical and yet hets such a disparity between the sounds.
post #7863 of 8069
BTW, now that I'm on my laptop and not my phone, it's easier to copy and paste and post so for those who missed my post about #5794:
Originally Posted by djbluemax1 View Post
BTW, I know a few folks here have recommended running a calibration (eg Audyssey) with the SubM HP's in Program 1 setting and then switching to Program 2 without a recalibration. For anyone wondering what this does, here are my graphs:
Equipment chain is
BDP: Oppo BDP-93
AVR: Onkyo TX-NR5008
Amps: Emotiva XPA-1 monoblocks
L/C/R: Boston Acoustics E100
Sub: Seaton Submersive HP
40Hz Crossover
Program 2 provides the low end bump in the graphs. The system was calibrated with Audyssey XT 32 in Program 1, then switched to Program 2 with no recalibration.
Max
As you can see, those were graphs of the full FR from 5Hz to 20kHz. Guess my memory is a little rusty. With my 40Hz crossover, the effect actually appears to begin at ~50Hz on down, but the important point is that both measurements are full FR and as is obvious, the differences above 50Hz are pretty much unimportant (I won't say non-existent as there are minute differences in the traces, which serves to show that they ARE 2 separate measurements, but for all intents and purposes, the differences are insignificant).
And to make it easier to find if anyone decides to search, I'm just going to add a bunch of terms that folks might use in the search engine
Submersive HP SubM graphs program 1 prgm 1 vs program 2 prgm 2 setting
REW graph
Program 1 vs program 2 tweak
prgm1 prgm2 house curve
Calibrate Audyssey with Program 1 then switch to Program 2 without recalibrating recalibration
Max
P.S. edited to add:
Also thought it would be pertinent to point out that Keith is using a 100Hz crossover in his setup with the measured results below, where I'm using a 40Hz crossover, but the Prgm 1 to Prm2 effect in both graphs clearly demonstrates that the effect is confined to the 50Hz and under region with no difference in the higher frequencies.
Originally Posted by kbarnes701 View Post
I didn’t see that in my measurements when I took 'before' and 'after' measurements of the difference Pgm2 vs Pgm1 made.
Can you please post your own measurements showing this 'pivot' phenomenon you describe?
Here is mine showing the effect of engaging Pgm2: (Edit - blue line is, obviously, Pgm 2, red line Pgm1)
I can’t find right now the graph showing the entire range up to 20KHz, but you will see from the one above that there is zero effect on the FR above about 45Hz and you can trust me that this zero effect continued all the way to 20KHz (as I would have expected).
I'd be interested to see your own graphs along with any explanation for the phenomenon you are describing. Thanks.
Net effect = Yep, Mark Seaton and his products ARE THE ABSOLUTE BOMB. What other sub out there not only has the power to be able to produce this, AND has such an easy means to create this house curve for deep bass lovers? That's right, NONE
Edited by djbluemax1 - 2/13/13 at 7:08am
post #7864 of 8069
Originally Posted by BeeMan458 View Post
And don't forget the 6, 12 or 24dB per octave slopes that by design, are built into different subwoofers. I don't see this issue often addressed.
Sorry,I don't follow?
post #7865 of 8069
The thing I don't understand is how you can have an such an allegedly huge audible difference that doesn't show up in measurements. Not everything you measure can be heard - but everything you hear can be measured.
Audyssey is not perfect by any means, but the far from standard procedure you are suggesting is unlikely to be the right solution IMO. The problem needs further investigation.
It depends on the measurements and the display. If the display is too coarse significant differences can be visually minimized, and more likely, measurements limited to just the subwoofer can hide major interaction issues with the main speakers which would be very audible. Alternately, measurements of only the speakers and sub could mask significant differences in the sub response. While less likely, Audyssey could be doing something different in the time domain which would be minorly visible in a magnitude response but quite audible. This would be the least likely cause, but not impossible.
post #7866 of 8069
Crossovers have roll offs to better integrate with the other speakers. As I'm sure you know, crossover points are not brick walls but, my understanding, tapered at a rate of -6/12/24dB per octave.
post #7867 of 8069
In the vast majority of cases this is handled by the surround processor's bass management. Unless otherwise noted, most use a 4th order low pass (24dB/oct) for the sub and 2nd order high pass (12dB/oct) for the high pass. Being that these are fixed for most processors except a few, that wouldn't affect differences being referenced.
post #7868 of 8069
I think he was referring to the "crossovers" on some subs. He likes to play around with those, even though he's also using the Bass Management in his receiver. Once again, he shows that he simply doesn't understand the adjustments he's making. His shotgun approach has gotten him to the point where is system is "Fouled Up Beyond All Recognition, (or FUBAR'd.) In another thread, he posted that after all his efforts, he can now listen enjoyably with the MVC at -60. He has obviously "fouled" up the calibration if -60 provides an enjoyable listening level. In my system, (which is properly calibrated for Dolby/DTS Reference Level), -60 is almost inaudible.
If he ever buys one of your subs, Mark, you need to go to his house and set it up for him... and then find some way to lock his system so he can't mess it up.
Craig
post #7869 of 8069
Craig
rolleyes.gif Wow, how many mod-deleted posts is it going to take?
post #7870 of 8069
Thanks Mark.
post #7871 of 8069
I don't understand your question, sorry. If you look at Craig's graphs above, with and without Audyssey, then you can see what you would expect to hear in his room, with Audyssey on and Audyssey off (in terms of FR at least). If Craig shows us some Waterfalls, we can also get an idea of what to expect in his room wrt to the tightness of his bass etc. And if he shows us some ETCs we can get an idea of what the imaging and soundstage will sound like. Is there something else that will affect the sound - something that can't be measured?
If there is, I don't know what it is. This is why I am puzzled by the assertion that the graphs are almost identical but the sound is vastly different, as well as by the assertion that Audyssey works differently with one type of sub than it does with another, which seems to me to be impossible.
I don't have ETC's because XTZ doesn't do them. I do have some waterfalls, but they're different than what you're used to looking at. They're "2D waterfalls" with time on the X axis and frequency on the Y axis. SPL is depicted by color with purple being the same intensity as the original sound, red being 10 dB down, yellow 20 dB down, cyan 30 dB down dark blue 40 dB down and black being 50 dB down. Here is my 2D waterfall without Audyssey. (You can see the color scale on the right-side Y axis.)
You can see that at about 25 Hz, there is a lot of energy that resonates for a long time; it's red out to 100 ms, and still yellow at 150 ms. Also at 125 Hz, there is another resonance, but it doesn't last as long as the one at 25 Hz. In the small frequency response graph in the upper right corner, you can see the peaks associated with the resonances. I have circled them here for clarity:
The next graph shows the effect of Audyssey in the time domain:
Note that the resonances are significantly tamed. The 25 Hz resonance is shorter and it has significantly less energy. The 125 Hz resonance is virtually gone. Audyssey sets filter taps in the time domain and these waterfalls are direct evidence that it works.
It is easy to get used to the sound of these resonances, and to notice when they're gone. Some will say, "Audyssey killed my bass." Again, I say, "Not so... Audyssey fixed the bass." The detail and articulation that is allowed to come through when these resonances are removed is astonishing.
Crabalocker, did you get to take any more measurements?
Craig
post #7872 of 8069
No not yet, been busy at work and just got my ChromaPure and D3 meter. I'm going to be calibrating my W7000, see how that goes. I had my JVC X-55 professional calibrated and it looks pretty awesome. Hope I can do a half as good on the BenQ. When that's done I'll start the ugly business of Audyssey....I can hardly wait!
post #7873 of 8069
Craig
Brilliant. Thanks for that Craig.
post #7874 of 8069
craig john,
Isn't there a minimum level that energy should resonate to sound accurate?
Otherwise you wind up with the equivalent of an over treated room.
post #7875 of 8069
craig john,
Obviously I'm not Craig, but I I don't know if that applies to bass. In my room, if I could get ZERO ringing in the lower registers, I would be happy. And at least one acoustician agrees with that since in his position you can never have too many bass traps -- that is Ethan Winer from Real Traps (at least that is what he told me). I'm sure other "acousticians" might feel differently.
post #7876 of 8069
craig john,
First, we are talking about the bass response, which is dominated by the modal response in the room. What happens in a room above the "transition frequency", (the point where the response transitions from modal to reverberant), is a whole different discussion. The psycho-acoustics of the modal response are completely different than the reverberant response.
Room modes or resonances occur in a room when the wavelength of a soundwave is close to a room dimension. The soundwaves bounce back and forth between the room boundaries and they reinforce each other. These resonances occur over very narrow bands of frequencies, as you can see in the graphs above. When those narrow bands of frequencies are louder and they decay longer than the rest of the frequencies, they dominate the sound you hear. Instead of hearing all the notes with articulation, you hear everything as one note, the note of the resonance. This can sound boomy or muddy or sloppy. Removing the resonance allows you to hear every note with the same intensity, (SPL), and decay as every other note. This increases the articulation and detail of the bass.
I can't imagine that there is ever any benefit to having a small band of frequencies dominate the response.
Craig
post #7877 of 8069
Interesting you bring up Ethan Winer. In one sentence he will tell you that you need massive bass trapping to reduce modal ringing; in he next sentence he will tell you that Audyssey can't possibly do what it does... only bass traps can work to reduce resonances: http://www.realtraps.com/art_audyssey.htm
Audyssey claims to flatten the response and reduce ringing over an area large enough to encompass multiple seats, so I measured at three adjacent locations on Kal's couch. It turns out this was not necessary because the MultEQ was unable to reduce ringing even at the same place it was calibrated for. As you can see in Figure 1 at left, the main improvement is a 6 dB reduction of the lowest response peak around 35 Hz.
Now, admittedly, this was from 2007, using a version of Audyssey, (MultEQ), that has since been superseded twice, by MultEQ XT and XT32. XT32, which is the version I'm using, has 256X the filter resolution on the mains and 4x the filter resolution on the subs. Nonetheless, he hasn't taken this down, nor backed off this stance.
Just sayin...
Craig
post #7878 of 8069
Good posts Craig. I think what Ethan is getting at is that Audyssey can't change the room, and the room causes the resonances. When you pull down the peaks you have attenuated the resonsances as they are having less energy excite them. On your graphs you can see how the levels are eq'd down ~6db, and at 25hz it is starting out pink and after aud. is orange-red. This can be seen with manual eq devices as well such as here between the antimode and the bfd. I am sure you already know this, just putting it out there. Obviously room treatment combined with eq will give best results in the time domain. smile.gif
http://www.hometheatershack.com/forums/electronic-processing-equalization-devices/11699-testing-dspeaker-anti-mode-8033-a.html#axzz2KkqHQN3y
Edited by Luke Kamp - 2/14/13 at 7:51am
post #7879 of 8069
Craig: I have the version of Audyssey that Ethan is referring to (in our family room) and it does little to nothing to reduce bass ringing. On the other hand, my guess would be that if I removed all of my bass traps (in my theater) my bass ringing would get worse.
But lest we forget, Ethan is in the business of selling physical product so room correction that reduces the need for that is not his friend. Plus, the "audiophools" (some of whom are Ethans prospects) don't believe in room correction (pure signal path and all of that).
I hope to have Dirac Live running on my server this weekend so it will be interesting to see how it does.
A good audio buddy just installed it and can't stop raving about. He also has Audyssey X32 on his Integra 80.3 so is familiar with it.
post #7880 of 8069
It makes sense, to me, that the less digital correction you need to do by first correcting the room with traps, absorbers and diffusers, the better digital processing should work.
I think maybe I'll try and measure the SubM without Audyssey or any other EQ and see if I can treat my room to correct the peaks and nulls that Audyssey might be over correcting then try Audyssey once again. Maybe this is a better approach.
post #7881 of 8069
Don't forget subwoofer placement and listening position optimization. Those is the most important determinants of the transfer function, (the transfer of the sound energy from the subwoofer(s) to the listening position.) Optimize your placements first, then run Audyssey.
And listening position is just as important as subwoofer placement. If your seating is against a wall, move it as far off the wall as possible. If it's in the center of the room, move it out of the center. These will make just as big a difference as the subwoofer placements.
Craig
post #7882 of 8069
Sorry, for the off topic post...
But do boom mic holders come with the adaptor or holder that will work with the audyssey mic?
post #7883 of 8069
Yes, it's a spring clip. Here's an example:
http://www.bhphotovideo.com/bnh/controller/home?Q=&A=endecaSearch&InitialSearch=yes&N=0&O=&Ntt=Microphone+Spring+Clip
Craig
post #7884 of 8069
Craig
@SOWK - Just in case you're asking if the boom mic holder comes with a low profile boom mic stand like I suggested in a prior post, then the answer is no.  You might want to consider investing a little more in something like this to provide greater flexibility with the Audyssey mic positioning as it threads directly into the Audyssey mic.  For something like an Omnimic, EMM-6 or UMM-6 mic, the adapter that comes with the mic can be screwed directly into the end of the boom arm.  Hope this helps.
post #7885 of 8069
craig john,
The problem with 'bass traps' as usually described is that they aren't really any such thing - they are broadband absorbers and they do next to nothing for the very deep bass frequencies, say 30Hz down. If you have persistent ringing there it is very hard to eliminate, as I have found myself. This is even more so if you have a small room like mine, with limited placement options for *everything*.  For example, it's a good idea to move the seats away from the walls and a bad idea to have the seats in the centre of the room. In my room, you don't need to move the seats very far from the wall and they ARE in the centre of the room :)
I am investigating what can be done about 20-30Hz ringing but I am not optimistic and may just have to live with it. It looks worse on waterfalls than it sounds to my ears.
post #7886 of 8069
The problem with 'bass traps' as usually described is that they aren't really any such thing - they are broadband absorbers and they do next to nothing for the very deep bass frequencies, say 30Hz down. .
They actually have almost no effect below 80Hz.
Make sure it's broke before you try to fix it. If you haven't made waterfall charts of your in-room response there's no way of being absolutely sure of what's going on. Even if you have response peaks that doesn't mean you have ringing at those frequencies. If do you have very low frequency ringing the source is most likely the flexing of the room walls, floor and ceiling, and you can't realistically do much of anything about that.
post #7887 of 8069
Indeed. I have graphed the response in REW using waterfalls. I have no problems until I get down to about 30Hz, which isn't so bad, then more at 20Hz or so, which is, as expected, worse. My main problem is my room - it is too small, a bad shape and offers little room for alternative placements of speakers, subs and seats. Unless or until we move house, I just have to live with it. I guess we all make compromises. I am fortunate that even in this crappy room the SQ is better than I woud have hoped in my wildest dreams thanks to good quality speakers and subs, room treatments and Audyssey XT32. I just wish I could deal with that very low end problem. Actually, it graphs worse than it sounds.
post #7888 of 8069
Unless I really missed something in your posts , KB, small rooms don't have to sound bad. I mean unless you have a WAF, treatments should not be an issue either. I have 8 treatments in my 9 1/2x12 1/2 x8f room. That plus proper speaker placement and XT32 has given me fantastic sound. I have treatments hanging on the all and the ceiling. Trust me, I did not want to do it and then when I did decide to do it I was only going to put 4 up. But after talking to a number of people, I ended up with 8. If you can't take pictures down for some reason or another, then you are just left with what a RC system can do for you. But my room went pretty far just with treatments. Even with my chairs very close to the back wall which I know is a no no. I could tell right away just by listening and looking at some measurements. With treatments and EQ, my combined FR is not too bad(sub is really flat). Plus it sounds really good. Craig can confirm this since he was the one that did all the EQ'ing. Don't let the fact that you have a small room make you think you are destined to have bad sound.
post #7889 of 8069
A poor crosssover can make you a bad sound.
post #7890 of 8069
How about solid concrete bunkers, all 4 walls , floor and ceiling solid 10-12" concrete?
