post #7891 of 8062
2/15/13 at 4:29am
- MIkeDuke
- Trader Feedback: 0
- No hype for me
- offline
- 5,275 Posts. Joined 12/2004
- Select All Posts By This User
OK. But, as I think I mentioned, I had someone come over, take measurements, and we then made cross over decisions based on the results we recorded. I understand that it's not just one thing that contributes to how good or how bad a room and system will sound. The idea is to try your best to take as many of those variables out of the equation and get the best sound you can. Everything taken together makes a system. I never said that it was only one thing that made a system sound bad or good. I was just saying that room treatments can work in a small room. I don't know how you got "A poor crosssover can make you a bad sound" from my post.
