AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Seaton Sound SubMersive1
Seaton Sound SubMersive1 - Page 286
post #8551 of 9378
So I am gonna need an XLR to RCA adapter to connect these HP's to my Denon 3313 correct?
post #8552 of 9378
Originally Posted by jlpowell84 View Post
Originally Posted by bsoko2 View Post
Quite frankly 4 Submersives (stacked in front L & R corner) in a sealed & treated 2000 sq ft room is not really needed so I sold 2 of them to jlpowell84. WWZ bass was just as good with 2 as it with 4. Audio friend from Oregon so I made him a good deal.
And I am extremely humbled and grateful. Dual 2.4kw HP's will be quite a step up from a single HSU VTF 15H with a 350 watt amp! I will have a 2 channel jbl setup until spring when I get my (most likely) JTR Noesis. Plus I scored one of the Sherbourn PA 7350 amps so it's slowly coming together! I am a grateful AVS-er as of lately! smile.gif
Great to hear that worked out for both of you. Do enjoy the new subs!
Of course we all know both of these guys are thinking they could upgrade to HP+ and slave in the future to get back to the bliss of quad SubMersives. cool.gif
post #8553 of 9378
Ha guess you got to know me a little from the gtg. I confess, I was on your new master/slave forum earlier looking at prices for the future! smile.gif
Or perhaps better stated you know people who are willing to spend thousands on subs are serious about their bass!
Edited by jlpowell84 - 9/24/13 at 1:54pm
post #8554 of 9378
Yes but if you purchased from seaton they come included.
post #8555 of 9378
They already come with the Submersives so don't worry and I do have subwoofer RCA cables.
Bill
post #8556 of 9378
post #8557 of 9378
Bill
I am using a very low quality RCA cable for connecting my SMS-1 to my receiver. This is probably a bad thing.
Does quality matter in RCA cables?
post #8558 of 9378
Originally Posted by ninja12 View Post
This looks good. Now, if you want to continue to tweak a little more, you can try improving the dip at 63 Hz. You can probably improve/remove that dip at 63 Hz by adjusting the subwoofer distance in your receiver/processor. Leave screen up so that you can instantly see if the change in distance is working. It's not unreasonable for the subwoofer distance to be greater than what you think it should be. For example, you may sit 10' from your sub; but, you may have to set the distance to 15' in order to remove the dip. So, I suggest playing around with the sub distance to see if that will help you out.
Good luck!
Moved distance across the board , but nothing changed. Also I know the volume on sms is just a utility gain but I never notice any changes to the sub volume...
post #8559 of 9378
^Guns man! They are fun too!
Guns are definitely fun.. But also expensive hobby if you go to the range alot.
Sig 226, H&K MK 23, DE .50AE
post #8560 of 9378
Jlpowell84.. Nice bro on the dual HP's. And you know those are upgradable to pluses. Imagine that. But I bet those duals HP will still shake the foundation and house..lol
post #8561 of 9378
Hey thanks rhed! Yes they come with good expandable future options biggrin.gif I'm sure I will be having fun for quite sometime. If I ever make it back to Honolulu you know I'll be over experiencing quad Captivator S2's! eek.gifeek.gifeek.gif
post #8562 of 9378
Yea bro.. Just hit me when you do come down. Maybe get some other A/Ver's around Honolulu and make a little GTG..biggrin.gif
post #8563 of 9378
Happy with the setup that I have when running just 2 Submersives and time to JUST enjoy it. I use that system for movies only and I have taken up a new hobby, going to the rifle range every weekend and target shooting. I shoot a AR15 Black Rain Fallout that is .223/5.56 and change will out the barrel to a .300 Blackout (new barrel ordered, Wilson Combat fluted stainless steel.300) . Dear wife of 44 years who passed away wouldn't allow a firearm in the house so I gave up shooting for her. I was a qualified Marine Rifle expert in the '60's and missed target shooting. Have just now taken it up again and my HT room is fine with what it's got. So changing hobbies is what decided my selling of the Submersives and jlpowell84 is putting together his dream system. Passing it forward with a good deal for him and one day he will do the same for someone else.
Bill
Sir you are both a class act and what everyman married should strive to be! and that's a loving husband!
+1
post #8564 of 9378
Bill
It matters in the sense that you want good mechanical performance from the cable - by that I mean you want properly made connectors that give a good connection plus good shielding and a durable sheath over the whole cable. Cables don't have a 'sound' as many of the snake-oil cable sellers would have you believe, so as long as they are reasonably well-made there's no need to spend a fortune. Monoprice cables are fantastic value for example, as are Blue Jeans. No need to spend any more.
post #8565 of 9378
Good point there. Yesterday I saw some rca cables worth about $1,000+!
post #8566 of 9378
You mean they were priced at $1,000 I assume. They are probably worth $15.
Here's an expensive cable - the reviews are very complimentary and well worth reading ;)
post #8567 of 9378
One of the advertisers here, Blue Jeans Cable has a lot of info on cables in general. (I am using XLR myself)
Here is a link to RCA info: http://www.bluejeanscable.com/store/subwoofer/index.htm
post #8568 of 9378
I'm not a fan of the monoprice RCA connectors any more. They have too stiff a connector and I feel like I"m going to break my RCA ouput on the AVR in order to plug them in. Sometimes I have to yank with both arms to pull the cable off. So while that is a tight connection - it's way too tight.
I've moved to Hosa cables for my new cables. They are available on amazon, are inexpensive, are of good quality rubber sleeves, and seem adequate for my use.
http://www.hosatech.com/category/325355/Analog_Audio
I have no experience with blue jeans cables - but I have heard good feedback about them as well - bonus that they are a forum supporter.
post #8569 of 9378
Better Cables http://www.bettercables.com/silver-serpent-anniversary-edition-audio-interconnect-cables.aspx has some good stuff if you are into silver coatings.
post #8570 of 9378
Bill
Of course it does!
Probably the worst thing about cheap cables is the connectors - what they are and how they are attached. Most cables fail within an inch or two of the ends. That said I've seen cheap cable that made me wonder why anybody wasted time terminating it.
I started building audio cables professionally at the age of 13 (1959) in a Lafayette Radio store and have built, installed, terminated and repaired tens of thousands of cables.
That all said, there are few home audio cables that can't be custom made by a good cable house (Markertek, BJC, etc.) for less than $50, many for less than $20, and off-the-shelf for $10- 30.
The cables that come with equipment are usually not top shelf, but they will probably work because if they don't, its a warranty hit just like the component itself failed. Their most common technical problem is that they are too short.
post #8571 of 9378
Here's an expensive cable - the reviews are very complimentary and well worth reading wink.gif
As curious as I am, I had to go take a look.
Man.....those reviews are a hoot !!!
post #8572 of 9378
Wonderfully entertaining aren't they?  And they seem to have identified the unique qualities of that cable very precisely too. ;)
post #8573 of 9378
Oh yea, look up the audio quest cables too. Amazon and other sites. They get even better!
post #8574 of 9378
T minus two days until I will be Submersified !!!!
Ps: Doubletime!
I had some fun playing around/setting up my new amp last night. Gotta get a couple drivers rebuilt out of my JBL loaner towers and we will be rockin!
post #8575 of 9378
post #8576 of 9378
Driving north to get the twin babies!
post #8577 of 9378
Hey I’m over here on the coast, practically on your way. Stop back on your way home and we’ll fire one of those guys up. Congrats! cool.gif
post #8578 of 9378
Where you at Steve?
post #8579 of 9378
^^^ I'm over here in Astoria!
EDIT> You know if I were still in the Portland area that might be feasible, or me come over and check it out? cool.gif
Edited by steve nn - 9/29/13 at 8:40am
post #8580 of 9378
Oh I got ya. Yea it's already gonna be 7.5 hours on the road today though. Perhaps another time. What kinda gear do you run?
