AVS › AVS Forum › Display Devices › Rear Projection Units › Please HELP RCA DLP Problem Pics!!
post #1 of 5
Hi to all, I had this isue for months...Can anyone help me with my RCA DLP 61". There is a black spot area (triangle) top left. it's there all the time.
Thank you and have the best day ever.
Rich
post #2 of 5
Is it still under warranty? Your best bet would be to have someone come out and look at it. If not, is there an access panel that allows you to see into the set? Looks like there's something partially blocking the light from reaching the screen in that corner...
post #3 of 5
Yes I will bring it to the dealer it's still on warranty. I want to know if anyone had this problem.
Rich
post #4 of 5
Do you mind if i ask what they repaired to fix the dark corner peroblem?
post #5 of 5
Problem found! one hair cat (pet)
  Back to Forum: Rear Projection Units
