I too am looking into getting a monoprice screen...
likely the 106", ~12'4" viewing distance, 17' deep x 14' wide room. I don't think I want the 120" as it'll force me to move out my mains a bit too far for optimal audio imaging without excessive side wall interaction, plus my subs start to get in the way placement-wise.
This will be a retractable, tab tensioned, recessed mounted screen. We're having new ceilings put in, so I figured this would be the perfect time. Once it's installed, I'm quite committed. Any concerns I should have? I'll be running (switched?) AC power to the screen, remote switch cables to both a wall plate location and back to the projector, and IR cabling (all CAT5/6 cable likely since it's very use-flexible). Construction starts in August, so I'll likely purchase this late July and start looking over the recessed mounting options. My ceiling joists run width-wise in the room, so that'll fit the screen between them nicely. Just trying NOT to screw this up. The contractor is not super familiar with such HT items.
