Originally Posted by
dino_navarro
Hello all,
I just confirmed Jeff's findings at my local BestBuy. The TV there at BB has firmware version 1011 where my DVD player worked fine at 1080i. My TV has version 1012. I have attached a picture of the version from both TVs. As you can seen on mine (ver 1012), there is a pink hue from the flicker. I will make sure Samsung sees this post.
Thanks, Dino. I just checked my firmware and it's 1012, also.
mrslloyd,
jeffng65 posted how to find the firmware version several posts up on this page (thanks jeff). Here are the steps:
1. Click "
Menu" button on your remote
2. Choose "
Setup"
3. Arrow down to the bottom and select "
Function Help"
4. Click your "
right" arrow button and you will get a display that reads "
On" and "
Off".
5. At this screen, click on your "
Info" button on your remote and then you should see the info at the top of the screen.
