So... the Goonies has two encodes on the disc.
It's not a PiP thing either since they're both "clean". The only difference as far as I can tell is that the director's/actors commentary is on the smaller encode but not on the bigger one... so why did it need a completely different encode?
EDIT: Ah hah, it is a PiP thing - but it's not the whole movie, only for certain bits, and they last maybe 30-60 seconds at most. Easy to miss when you're skipping through the movie!
Why bother though if it's for maybe 5% of the movie?
Code:
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
The Goonies (UK) (Main Encode) VC-1 1:53:55 25,606,225,920 47,887,564,623 29.97 22.44 Dolby TrueHD 5.1 1747Kbps (48kHz/16-bit) DD AC3 5.1 640Kbps
Code:
DISC INFO: Disc Title: THE_GOONIES Disc Size: 47,887,564,623 bytes Protection: AACS BD-Java: No PLAYLIST REPORT: Name: 00000.mpls Size: 25,606,225,920 bytes Length: 1:53:55 (h:m:s) Total Bitrate: 29.97 Mbps Description: FILES: Name Size Length Time In Time Out ---- ---- ------ ------- -------- 00113.M2TS 25,606,225,920 1:53:55.328 0:00:00.000 1:53:55.328 VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 22443 kbps 1080p / 23.976fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby TrueHD Audio English 1747 kbps 5.1 / 48kHz / 16-bit / 1747kbps (AC3 Core: 5.1 / 48kHz / 640kbps) Dolby Digital Audio English 640 kbps 5.1 / 48kHz / 640kbps Dolby Digital Audio English 192 kbps 2.0 / 48kHz / 192kbps Dolby Digital Audio English 192 kbps 2.0 / 48kHz / 192kbps Dolby Digital Audio French 192 kbps 2.0 / 48kHz / 192kbps Dolby Digital Audio Japanese 192 kbps 2.0 / 48kHz / 192kbps Dolby Digital Audio Spanish 192 kbps 1.0 / 48kHz / 192kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 70.817 kbps Presentation Graphics English 37.194 kbps Presentation Graphics Chinese 31.248 kbps Presentation Graphics Chinese 54.099 kbps Presentation Graphics Dutch 29.351 kbps Presentation Graphics Dutch 57.150 kbps Presentation Graphics French 23.532 kbps Presentation Graphics French 54.066 kbps Presentation Graphics Japanese 22.192 kbps Presentation Graphics Japanese 0.446 kbps Presentation Graphics Japanese 47.244 kbps Presentation Graphics Korean 19.630 kbps Presentation Graphics Korean 46.286 kbps Presentation Graphics Portuguese 27.215 kbps Presentation Graphics Portuguese 64.471 kbps Presentation Graphics Spanish 29.029 kbps Presentation Graphics Spanish 65.533 kbps CHAPTERS: Number Time Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ---- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:05:04.888 22,478 kbps 51,204 kbps 00:00:02.169 32,291 kbps 00:02:00.621 29,458 kbps 00:02:00.871 117,192 bytes 502,876 bytes 00:01:13.240 2 0:05:04.888 0:02:04.082 18,198 kbps 26,346 kbps 00:07:05.884 22,977 kbps 00:07:03.298 22,333 kbps 00:06:56.708 94,876 bytes 400,924 bytes 00:06:50.160 3 0:07:08.970 0:02:45.666 20,812 kbps 44,586 kbps 00:09:12.719 29,557 kbps 00:08:57.328 26,425 kbps 00:08:54.659 108,505 bytes 447,118 bytes 00:09:12.761 4 0:09:54.636 0:03:55.068 20,121 kbps 36,184 kbps 00:10:40.932 28,923 kbps 00:10:38.721 25,893 kbps 00:11:58.426 104,899 bytes 403,336 bytes 00:11:08.376 5 0:13:49.704 0:06:12.789 22,427 kbps 33,847 kbps 00:19:00.890 28,670 kbps 00:18:56.927 27,220 kbps 00:16:12.305 116,924 bytes 409,277 bytes 00:16:15.516 6 0:20:02.493 0:02:42.579 22,058 kbps 34,504 kbps 00:21:13.272 29,960 kbps 00:21:13.272 27,211 kbps 00:21:11.312 115,003 bytes 381,088 bytes 00:20:48.622 7 0:22:45.072 0:02:52.673 23,918 kbps 35,226 kbps 00:24:48.445 29,838 kbps 00:24:47.861 28,372 kbps 00:23:17.146 124,700 bytes 512,771 bytes 00:24:47.903 8 0:25:37.745 0:01:35.595 24,576 kbps 32,384 kbps 00:26:05.773 28,576 kbps 00:26:04.772 28,042 kbps 00:26:03.479 128,126 bytes 477,087 bytes 00:27:11.880 9 0:27:13.340 0:03:27.416 22,550 kbps 38,619 kbps 00:30:31.246 30,353 kbps 00:30:29.661 28,608 kbps 00:30:24.740 117,564 bytes 448,031 bytes 00:30:31.788 10 0:30:40.756 0:02:53.548 22,853 kbps 40,182 kbps 00:32:19.521 31,827 kbps 00:33:28.882 29,419 kbps 00:33:24.294 119,146 bytes 423,475 bytes 00:32:20.063 11 0:33:34.304 0:03:14.194 21,847 kbps 33,782 kbps 00:34:43.832 29,750 kbps 00:34:57.262 27,574 kbps 00:34:42.455 113,902 bytes 472,648 bytes 00:36:05.330 12 0:36:48.498 0:01:54.031 22,213 kbps 38,105 kbps 00:38:09.412 30,918 kbps 00:38:08.328 28,660 kbps 00:38:07.494 115,806 bytes 518,798 bytes 00:38:02.655 13 0:38:42.529 0:03:31.085 22,495 kbps 37,488 kbps 00:42:03.146 29,999 kbps 00:40:12.452 28,313 kbps 00:40:12.327 117,277 bytes 414,711 bytes 00:40:00.732 14 0:42:13.614 0:03:57.154 24,708 kbps 37,947 kbps 00:45:01.282 30,241 kbps 00:44:28.875 28,306 kbps 00:45:29.894 128,818 bytes 490,209 bytes 00:45:00.323 15 0:46:10.768 0:02:32.527 24,238 kbps 38,531 kbps 00:46:30.621 31,434 kbps 00:46:27.576 28,262 kbps 00:46:27.576 126,365 bytes 424,295 bytes 00:47:17.334 16 0:48:43.295 0:01:04.481 23,393 kbps 32,676 kbps 00:48:56.600 29,110 kbps 00:48:47.383 28,275 kbps 00:48:47.424 121,961 bytes 341,732 bytes 00:49:20.875 17 0:49:47.776 0:03:04.727 24,799 kbps 41,385 kbps 00:50:37.660 31,700 kbps 00:51:11.860 29,202 kbps 00:51:13.195 129,293 bytes 515,115 bytes 00:50:38.202 18 0:52:52.503 0:02:55.633 23,383 kbps 38,227 kbps 00:52:58.133 31,511 kbps 00:54:42.905 28,754 kbps 00:54:43.071 121,910 bytes 435,734 bytes 00:53:39.425 19 0:55:48.136 0:02:24.353 23,237 kbps 35,781 kbps 00:56:33.974 29,746 kbps 00:56:01.233 27,460 kbps 00:56:02.985 121,147 bytes 438,209 bytes 00:57:01.543 20 0:58:12.489 0:01:18.996 23,787 kbps 37,887 kbps 00:58:56.533 29,239 kbps 00:58:37.055 27,593 kbps 00:58:31.591 124,015 bytes 446,567 bytes 00:58:41.560 21 0:59:31.485 0:04:02.992 24,428 kbps 38,428 kbps 01:01:47.746 29,791 kbps 01:03:07.993 27,925 kbps 01:03:07.200 127,358 bytes 513,003 bytes 01:01:56.379 22 1:03:34.477 0:03:37.593 22,901 kbps 37,798 kbps 01:06:47.378 30,755 kbps 01:06:47.378 29,110 kbps 01:06:47.378 119,394 bytes 465,265 bytes 01:06:13.928 23 1:07:12.070 0:02:34.195 24,593 kbps 40,164 kbps 01:08:02.996 31,158 kbps 01:07:59.867 28,387 kbps 01:07:54.862 128,216 bytes 610,149 bytes 01:08:25.685 24 1:09:46.265 0:03:01.807 22,691 kbps 31,045 kbps 01:12:40.398 28,812 kbps 01:12:36.561 28,302 kbps 01:12:36.143 118,298 bytes 388,536 bytes 01:11:57.563 25 1:12:48.072 0:02:32.444 22,315 kbps 35,212 kbps 01:14:04.023 30,457 kbps 01:14:04.023 27,967 kbps 01:14:04.023 116,339 bytes 499,098 bytes 01:12:48.114 26 1:15:20.516 0:02:58.261 24,564 kbps 38,575 kbps 01:17:01.450 30,783 kbps 01:15:31.026 28,178 kbps 01:15:26.021 128,064 bytes 464,956 bytes 01:16:01.265 27 1:18:18.777 0:03:48.187 23,690 kbps 41,198 kbps 01:21:04.068 31,652 kbps 01:19:25.678 29,162 kbps 01:20:29.158 123,511 bytes 489,077 bytes 01:21:44.691 28 1:22:06.964 0:01:33.009 24,171 kbps 36,494 kbps 01:22:39.204 29,892 kbps 01:22:38.245 28,296 kbps 01:22:33.740 126,016 bytes 503,642 bytes 01:22:36.326 29 1:23:39.973 0:03:35.424 24,402 kbps 37,706 kbps 01:24:00.744 32,024 kbps 01:24:30.857 27,959 kbps 01:24:06.917 127,223 bytes 508,881 bytes 01:24:10.671 30 1:27:15.397 0:03:18.907 20,730 kbps 37,427 kbps 01:27:19.651 32,239 kbps 01:27:18.650 27,960 kbps 01:27:15.689 108,079 bytes 490,639 bytes 01:30:09.696 31 1:30:34.304 0:03:05.393 23,519 kbps 38,793 kbps 01:32:46.227 29,986 kbps 01:32:42.682 27,543 kbps 01:32:43.850 122,615 bytes 507,799 bytes 01:32:24.664 32 1:33:39.697 0:04:59.591 25,030 kbps 39,418 kbps 01:37:39.270 29,172 kbps 01:38:19.977 27,662 kbps 01:38:19.977 130,494 bytes 354,186 bytes 01:35:20.548 33 1:38:39.288 0:02:48.502 23,503 kbps 36,526 kbps 01:41:03.140 29,496 kbps 01:41:03.057 28,433 kbps 01:39:07.150 122,532 bytes 576,084 bytes 01:38:59.016 34 1:41:27.790 0:03:47.602 24,646 kbps 39,418 kbps 01:44:36.812 31,051 kbps 01:44:36.812 28,678 kbps 01:44:32.308 128,493 bytes 547,560 bytes 01:44:28.262 35 1:45:15.392 0:01:57.993 25,645 kbps 37,040 kbps 01:46:48.736 31,737 kbps 01:46:02.731 28,504 kbps 01:46:42.187 133,699 bytes 607,594 bytes 01:45:43.671 36 1:47:13.385 0:01:17.953 24,393 kbps 33,047 kbps 01:47:13.427 29,975 kbps 01:48:08.982 27,204 kbps 01:47:13.719 127,172 bytes 373,595 bytes 01:48:13.904 37 1:48:31.338 0:05:23.990 7,816 kbps 36,640 kbps 01:53:35.976 26,813 kbps 01:48:46.895 25,939 kbps 01:48:41.890 40,749 bytes 544,132 bytes 01:53:51.992 STREAM DIAGNOSTICS: File PID Type Codec Lang. Code Lang. Name Seconds Bytes Packets Bitrate ---- --- ---- ----- ---------- ---------- ------- ----- ------- ------- 00113.M2TS 4113 (0x1011) 0xEA VC-1 6835.33 19,175,984,160 104,315,999 22,443 00113.M2TS 4352 (0x1100) 0x81 AC3 eng English 6835.33 546,828,800 3,204,075 640 00113.M2TS 4353 (0x1101) 0x83 TrueHD eng English 6835.33 2,039,498,206 16,860,865 2,387 00113.M2TS 4354 (0x1102) 0x81 AC3 eng English 6835.33 164,048,640 1,068,025 192 00113.M2TS 4355 (0x1103) 0x81 AC3 fra French 6835.33 164,048,640 1,068,025 192 00113.M2TS 4356 (0x1104) 0x81 AC3 spa Spanish 6835.33 164,048,640 1,068,025 192 00113.M2TS 4357 (0x1105) 0x81 AC3 jpn Japanese 6835.33 164,048,640 1,068,025 192 00113.M2TS 4358 (0x1106) 0x81 AC3 eng English 6835.33 164,048,640 1,068,025 192 00113.M2TS 4608 (0x1200) 0x90 PGS jpn Japanese 6835.33 18,960,992 111,299 22 00113.M2TS 4609 (0x1201) 0x90 PGS eng English 6835.33 31,779,021 183,031 37 00113.M2TS 4610 (0x1202) 0x90 PGS fra French 6835.33 20,106,328 116,422 24 00113.M2TS 4611 (0x1203) 0x90 PGS nld Dutch 6835.33 25,078,167 143,354 29 00113.M2TS 4612 (0x1204) 0x90 PGS zho Chinese 6835.33 26,698,645 153,962 31 00113.M2TS 4613 (0x1205) 0x90 PGS kor Korean 6835.33 16,772,136 99,526 20 00113.M2TS 4614 (0x1206) 0x90 PGS spa Spanish 6835.33 24,802,689 143,537 29 00113.M2TS 4615 (0x1207) 0x90 PGS por Portuguese 6835.33 23,253,093 133,805 27 00113.M2TS 4616 (0x1208) 0x90 PGS jpn Japanese 6835.33 380,692 2,259 0 00113.M2TS 4617 (0x1209) 0x90 PGS jpn Japanese 6835.33 40,366,069 232,023 47 00113.M2TS 4618 (0x120A) 0x90 PGS eng English 6835.33 60,507,280 345,196 71 00113.M2TS 4619 (0x120B) 0x90 PGS fra French 6835.33 46,194,894 266,275 54 00113.M2TS 4620 (0x120C) 0x90 PGS nld Dutch 6835.33 48,829,766 280,223 57 00113.M2TS 4621 (0x120D) 0x90 PGS zho Chinese 6835.33 46,222,798 266,331 54 00113.M2TS 4622 (0x120E) 0x90 PGS kor Korean 6835.33 39,547,413 230,210 46 00113.M2TS 4623 (0x120F) 0x90 PGS spa Spanish 6835.33 55,992,717 320,492 66 00113.M2TS 4624 (0x1210) 0x90 PGS por Portuguese 6835.33 55,084,991 315,013 64
Code:
Total Video
The Goonies (UK) ("Commentary" Encode) VC-1 1:53:55 20,457,381,888 47,887,564,623 23.94 22.16 DD AC3 2.0 192Kbps
Code:
DISC INFO: Disc Title: THE_GOONIES Disc Size: 47,887,564,623 bytes Protection: AACS BD-Java: No PLAYLIST REPORT: Name: 00008.mpls Size: 20,457,381,888 bytes Length: 1:53:55 (h:m:s) Total Bitrate: 23.94 Mbps Description: FILES: Name Size Length Time In Time Out ---- ---- ------ ------- -------- 00112.M2TS 20,457,381,888 1:53:55.328 0:00:00.000 1:53:55.328 VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 22159 kbps 1080p / 23.976fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby Digital Audio English 192 kbps 2.0 / 48kHz / 192kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 70.817 kbps Presentation Graphics Chinese 54.099 kbps Presentation Graphics Dutch 57.150 kbps Presentation Graphics French 54.066 kbps Presentation Graphics Japanese 47.244 kbps Presentation Graphics Korean 46.286 kbps Presentation Graphics Portuguese 64.471 kbps Presentation Graphics Spanish 65.533 kbps CHAPTERS: Number Time Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ---- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:00:02.002 212 kbps 211 kbps 00:00:00.000 0 kbps 00:00:00.000 0 kbps 00:00:00.000 1,105 bytes 9,233 bytes 00:00:00.042 2 0:00:02.002 0:05:02.886 23,466 kbps 51,204 kbps 00:00:02.169 32,291 kbps 00:02:00.621 29,458 kbps 00:02:00.871 122,339 bytes 502,876 bytes 00:01:13.240 3 0:05:04.888 0:02:04.082 18,274 kbps 27,473 kbps 00:06:50.785 24,270 kbps 00:07:03.965 23,212 kbps 00:06:58.960 95,274 bytes 382,700 bytes 00:05:47.681 4 0:07:08.970 0:02:45.666 20,631 kbps 44,586 kbps 00:09:12.719 29,557 kbps 00:08:57.328 26,425 kbps 00:08:54.659 107,561 bytes 447,118 bytes 00:09:12.761 5 0:09:54.636 0:03:55.068 20,121 kbps 36,184 kbps 00:10:40.932 28,923 kbps 00:10:38.721 25,893 kbps 00:11:58.426 104,899 bytes 403,336 bytes 00:11:08.376 6 0:13:49.704 0:06:12.789 22,427 kbps 33,847 kbps 00:19:00.890 28,670 kbps 00:18:56.927 27,220 kbps 00:16:12.305 116,924 bytes 409,277 bytes 00:16:15.516 7 0:20:02.493 0:02:42.579 22,058 kbps 34,504 kbps 00:21:13.272 29,960 kbps 00:21:13.272 27,211 kbps 00:21:11.312 115,003 bytes 381,088 bytes 00:20:48.622 8 0:22:45.072 0:02:52.673 23,918 kbps 35,226 kbps 00:24:48.445 29,838 kbps 00:24:47.861 28,372 kbps 00:23:17.146 124,700 bytes 512,771 bytes 00:24:47.903 9 0:25:37.745 0:01:35.595 24,576 kbps 32,384 kbps 00:26:05.773 28,576 kbps 00:26:04.772 28,042 kbps 00:26:03.479 128,126 bytes 477,087 bytes 00:27:11.880 10 0:27:13.340 0:03:27.416 21,452 kbps 30,090 kbps 00:27:47.291 27,424 kbps 00:27:22.015 26,829 kbps 00:27:20.681 111,843 bytes 380,953 bytes 00:28:20.449 11 0:30:40.756 0:02:53.548 22,522 kbps 40,182 kbps 00:32:19.521 31,827 kbps 00:33:28.882 29,419 kbps 00:33:24.294 117,418 bytes 423,475 bytes 00:32:20.063 12 0:33:34.304 0:03:14.194 22,254 kbps 33,782 kbps 00:34:43.832 29,750 kbps 00:34:57.262 27,574 kbps 00:34:42.455 116,020 bytes 472,648 bytes 00:36:05.330 13 0:36:48.498 0:01:54.031 22,213 kbps 38,105 kbps 00:38:09.412 30,918 kbps 00:38:08.328 28,660 kbps 00:38:07.494 115,806 bytes 518,798 bytes 00:38:02.655 14 0:38:42.529 0:03:31.085 21,958 kbps 34,429 kbps 00:41:44.836 29,999 kbps 00:40:12.452 28,313 kbps 00:40:12.327 114,478 bytes 414,711 bytes 00:40:00.732 15 0:42:13.614 0:03:57.154 24,585 kbps 37,947 kbps 00:45:01.282 30,241 kbps 00:44:28.875 28,306 kbps 00:45:29.894 128,177 bytes 490,209 bytes 00:45:00.323 16 0:46:10.768 0:02:32.527 24,238 kbps 38,531 kbps 00:46:30.621 31,434 kbps 00:46:27.576 28,262 kbps 00:46:27.576 126,365 bytes 424,295 bytes 00:47:17.334 17 0:48:43.295 0:01:04.481 23,393 kbps 32,676 kbps 00:48:56.600 29,110 kbps 00:48:47.383 28,275 kbps 00:48:47.424 121,961 bytes 341,732 bytes 00:49:20.875 18 0:49:47.776 0:03:04.727 24,799 kbps 41,385 kbps 00:50:37.660 31,700 kbps 00:51:11.860 29,202 kbps 00:51:13.195 129,293 bytes 515,115 bytes 00:50:38.202 19 0:52:52.503 0:02:55.633 23,383 kbps 38,227 kbps 00:52:58.133 31,511 kbps 00:54:42.905 28,754 kbps 00:54:43.071 121,910 bytes 435,734 bytes 00:53:39.425 20 0:55:48.136 0:02:24.353 23,237 kbps 35,781 kbps 00:56:33.974 29,746 kbps 00:56:01.233 27,460 kbps 00:56:02.985 121,147 bytes 438,209 bytes 00:57:01.543 21 0:58:12.489 0:01:18.996 23,787 kbps 37,887 kbps 00:58:56.533 29,239 kbps 00:58:37.055 27,593 kbps 00:58:31.591 124,015 bytes 446,567 bytes 00:58:41.560 22 0:59:31.485 0:04:02.992 22,107 kbps 34,536 kbps 01:02:55.021 29,791 kbps 01:03:07.993 27,925 kbps 01:03:07.200 115,256 bytes 446,269 bytes 01:02:36.795 23 1:03:34.477 0:03:37.593 22,901 kbps 37,798 kbps 01:06:47.378 30,755 kbps 01:06:47.378 29,110 kbps 01:06:47.378 119,394 bytes 465,265 bytes 01:06:13.928 24 1:07:12.070 0:02:34.195 24,593 kbps 40,164 kbps 01:08:02.996 31,158 kbps 01:07:59.867 28,387 kbps 01:07:54.862 128,216 bytes 610,149 bytes 01:08:25.685 25 1:09:46.265 0:03:01.807 22,691 kbps 31,045 kbps 01:12:40.398 28,812 kbps 01:12:36.561 28,302 kbps 01:12:36.143 118,298 bytes 388,536 bytes 01:11:57.563 26 1:12:48.072 0:02:32.444 22,315 kbps 35,212 kbps 01:14:04.023 30,457 kbps 01:14:04.023 27,967 kbps 01:14:04.023 116,339 bytes 499,098 bytes 01:12:48.114 27 1:15:20.516 0:02:58.261 23,529 kbps 38,575 kbps 01:17:01.450 30,783 kbps 01:15:31.026 28,178 kbps 01:15:26.021 122,667 bytes 464,956 bytes 01:16:01.265 28 1:18:18.777 0:03:48.187 22,457 kbps 41,198 kbps 01:21:04.068 31,652 kbps 01:19:25.678 28,648 kbps 01:19:26.053 117,081 bytes 478,078 bytes 01:19:29.181 29 1:22:06.964 0:01:33.009 23,050 kbps 36,494 kbps 01:22:39.204 29,892 kbps 01:22:38.245 28,296 kbps 01:22:33.740 120,173 bytes 503,642 bytes 01:22:36.326 30 1:23:39.973 0:03:35.424 22,518 kbps 33,277 kbps 01:27:04.428 30,106 kbps 01:27:02.676 27,812 kbps 01:27:02.884 117,398 bytes 461,298 bytes 01:26:47.244 31 1:27:15.397 0:03:18.907 20,730 kbps 37,427 kbps 01:27:19.651 32,239 kbps 01:27:18.650 27,960 kbps 01:27:15.689 108,079 bytes 490,639 bytes 01:30:09.696 32 1:30:34.304 0:03:05.393 22,884 kbps 35,530 kbps 01:33:24.015 27,477 kbps 01:32:23.496 26,118 kbps 01:30:35.639 119,308 bytes 507,799 bytes 01:32:24.664 33 1:33:39.697 0:04:59.591 24,455 kbps 39,418 kbps 01:37:39.270 29,172 kbps 01:38:19.977 27,662 kbps 01:38:19.977 127,495 bytes 354,186 bytes 01:35:20.548 34 1:38:39.288 0:02:48.502 23,503 kbps 36,526 kbps 01:41:03.140 29,496 kbps 01:41:03.057 28,433 kbps 01:39:07.150 122,532 bytes 576,084 bytes 01:38:59.016 35 1:41:27.790 0:03:47.602 23,877 kbps 39,418 kbps 01:44:36.812 31,051 kbps 01:44:36.812 28,678 kbps 01:44:32.308 124,483 bytes 547,560 bytes 01:44:28.262 36 1:45:15.392 0:01:57.993 25,645 kbps 37,040 kbps 01:46:48.736 31,737 kbps 01:46:02.731 28,504 kbps 01:46:42.187 133,699 bytes 607,594 bytes 01:45:43.671 37 1:47:13.385 0:01:17.953 24,393 kbps 33,047 kbps 01:47:13.427 29,975 kbps 01:48:08.982 27,204 kbps 01:47:13.719 127,172 bytes 373,595 bytes 01:48:13.904 38 1:48:31.338 0:05:23.990 8,365 kbps 36,640 kbps 01:53:35.976 26,813 kbps 01:48:46.895 25,939 kbps 01:48:41.890 43,614 bytes 544,132 bytes 01:53:51.992 STREAM DIAGNOSTICS: File PID Type Codec Lang. Code Lang. Name Seconds Bytes Packets Bitrate ---- --- ---- ----- ---------- ---------- ------- ----- ------- ------- 00112.M2TS 4113 (0x1011) 0xEA VC-1 6835.33 18,933,113,688 102,996,081 22,159 00112.M2TS 4352 (0x1100) 0x81 AC3 eng English 6835.33 164,048,640 1,068,025 192 00112.M2TS 4608 (0x1200) 0x90 PGS jpn Japanese 6835.33 40,366,069 232,023 47 00112.M2TS 4609 (0x1201) 0x90 PGS eng English 6835.33 60,507,280 345,196 71 00112.M2TS 4610 (0x1202) 0x90 PGS fra French 6835.33 46,194,894 266,275 54 00112.M2TS 4611 (0x1203) 0x90 PGS nld Dutch 6835.33 48,829,766 280,223 57 00112.M2TS 4612 (0x1204) 0x90 PGS zho Chinese 6835.33 46,222,798 266,331 54 00112.M2TS 4613 (0x1205) 0x90 PGS kor Korean 6835.33 39,547,413 230,210 46 00112.M2TS 4614 (0x1206) 0x90 PGS spa Spanish 6835.33 55,992,717 320,492 66 00112.M2TS 4615 (0x1207) 0x90 PGS por Portuguese 6835.33 55,084,991 315,013 64
Hopefully it's a quality master too (though I never understood the appeal of this movie personally - bring on Gremlins).
