Had this over in General Gaming, but got no response. Moving it here.
Hey folks.
I own a 5x1 HDMI switch from Monoprice and a PS3. I am using good cables from Monoprice as well, but I am not able to get the HDMI signal from my PS3 to work through the HDMI switch.
I have a 45' Monoprice HDMI cable running from the switch to my Panasonic AE900U projector. I can connect the PS3 directly to the projector with this same cable and it works fine (i.e. looks AWESOME!). But when I connect the PS3 to the switch with a 3' Monoprice HDMI cable (and use the 45' cable from the switch to the projector), I get no video at all.
Now this switch works great with all my other HDMI equipment. I've swapped ports. I've tried booting things in different order, but no success.
Has anyone else had this problem? It may be a problem with the Sony HDMI port. I know they support HDMI 1.3, but I don't see why that would cause a problem like this.
If you can think of anything helpful, I would very much appreciate it.
Hey folks.
I just ordered one of these 5x1... Thank you for the feedback
Also I tested the PS3 with the Yamaha for HDMI switching and was also getting HDMI droputs similar to what I saw with port 2 on the Monoprice so I decided to attach my Toshiba HD-A1 HD-DVD player along with my PS3 (at port 5 only) to the Monoprice and then output via HDMI to the HDMI input on the Yamaha receiver and use the Monoprice to switch between those 2 sources.
