I posted previously that I bought a Magnavox MRV700 combo recorder on e-bay because it had component inputs. I wanted to test it for component input then s-video out. It was an as is item that said it could not record to either VHS or DVD. I was just interested in the conversion capabilities so it didn't really matter. I paid $5.50 with $11.55 for shipping.
Double good news. The MRV700 is fully functional. Nothing wrong with it. It just needed a remote. It works great and is a pretty darn good unit. I don't know what I'm going to do with the VHS - I haven't had a VHS in probably 5 or 6 years.
Now for the component to s-video conversion. It works great. The quality is excellent. For those of you with an HD cable box that only outputs 480i wide screen over component this (or something like it) may be a solution for wide screen recordings.
It's a lot cheaper than those $350 converter boxes. And if you have a DVD recorder that you really like (with only s-video inputs) using something like the MRV700 as a converter may work out. It has/does for me.
My Motorola 6412 won't ouput 16:9 480i-
