I am a complete building newbie. I am learning as I go--reading tons of manuals, IRC, etc.
I am attempting to finish my basement for a nice media/home theater room. I decided to go ahead and get a permit but now I am regretting such a decision. Seems like there are so many rules that aren't exactly specified.
Anyway, I spoke with the building planner this morning and he said that I can't connect the top plate to the ceiling joist because the floor above needs be able to flex. Granted this is a non-bearing ball (partition wall).
Are there ways to adequately attach a top plate without directly nailing into the ceiling joists? Or should I get a second opinion because every single "basement finishing guide" says "attach top plate to ceiling joists?"
Please I need some help. I am beginning this project if I get past the permit stage on Dec. 16th.
Ask why this is such. I am with you, everything I have ever read about framing says attach the walls to the joists. I suspect the load bearing walls are attached directly to the joists, right? Why would you want the floors to flex? Seems like a flexing floor would lead to cracked tiles or gaps in the hardwood floors above. I guess there may be extreme situation such as earthquake zones, extreme temperatures, etc that may play a role in the local code.
My understanding is this gap is to allow the basement floor to "flex" up/down with the movement of the ground beneath the foundation without disturbing the joists and possibly lifting them off the foundation and causing all kinds of problems.
