I have a G4 Mac Mini, which has practically no useable storage space. So I've bought a couple external hard drives, including a Newertech Ministack. With almost a terabyte of immediately-available space, I'm running out of space again, between a growing iTunes collection (MP3s and ALAC) and EyeTV high-def recordings and need a different approach from adding more external drives to the rack.
Right now I have three external drives, all scattershot with different media. I'd like to organize things to three drives again, but with a better scheme: 1 boot drive (to initially record HD), 1 iTunes drive, and 1 drive to offload HD content and FLACs (i.e. from Dimeadozen). I'll use an existing 250GB external for iTunes. It's the boot/backup drives where I'm not sure what to do (I'm selling the Ministack, which works fine but the hubs don't help enough to keep)
I have 7 internal IDE drives for those two jobs, but I don't need to access them all at once, so I don't want to buy external enclosures for each one or buy a RAID setup. Also, in WAF terms, I'd like to keep the budget to $100 or less and find a solution that's as quiet as possible.
One solution is to buy two firewire enclosures, boot with one, and swap drives in the other. Pros: cost (easy to find solid enclosures for $50/each), easy-to-use firewire chain. Cons: two enclosures = two electrical outlets, two power supplies, etc.; swapping drives would be a bigger hassle.
Another solution is to buy a two-drive firewire enclosure, like AMS's Venus DSR3, use one bay to boot and another for backup. Pros: drives are easy to swap, only one unit to power/cool. Cons: more expensive ($150), don't know how EyeTV will work with JBOD set-up, don't know if drives/fan will sleep with machine and not wake it up.
I really like Wiebetech's Traydock, but the cheapest the off-brand (Sohotank, same thing) is with two trays is $75 (that I've found), and that's USB-only. Not much money left to buy a FW case that's dependable enough to boot from.
Any thoughts on this? I'd like to simplify the setup as much as possible. Any real-life experience with JBOD and EyeTV500s would be a great help. I know the boot drive needs to be in front of the EyeTV500. Does the EyeTV always need to be last in the chain?
Ever get firewire addressing conflicts on external interfaces? Bought some Oxford 924 interfaces to build some enclosures and they all had the same address. We were one of the first to complain to Oxford, and they had to update their flashing utility to handle it after the boards were publically released in the spring.
