AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Converting FLV to AVI
post #1 of 7
I have tried downloading several free trials for programs that are supposed to convert YouTube videos (which I can save as FLV format) to AVI files, but I'm not having any luck successfully converting. Does anyone have any ideas how I can do this or know of any programs that work well? Thanks.
post #2 of 7
I work at a TV station in Nashville... and I have been using a product called Moyea FLV to Video Converter. It is the only way I have been able to get YouTube videos converted so we can import them into our editing system. You can convert to AVI, or Quicktime. The program has a free trial.
http://www.flash-video-mx.com/flv_to_video_web/
Hope this helps,
Cam
post #3 of 7
Total Video Converter works like a dream. Google for it, there is a free trial.
post #4 of 7
i have a program called Video to Flash Converter ( geovid's company, it can be found easily with google ), it converts any video formats (most popular) to flash (swf and avi). i think you can use it, it has free trial version- i've been using it quite for a long time and was fully satisfied.
post #5 of 7
I'm using this FLV to AVI converter with luck:
post #6 of 7
I use Flash To Video Encoder!
post #7 of 7
SUPER is a great video converting tool. It will convert almost anything to anything...
  Back to Forum: Home A/V Distribution
