AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Optoma DV10 speakers question
post #1 of 6
I'm trying to use Headphones with DV10 projector. There is an audio out connector on DV10 that is same as a headphone jack. The problem is that the DV10 speakers don't turn off after I plug in the headphone !
In general, if I want to connect external speakers using the headphone jack, how do I turn off the built in speakers ? If volume is turned to zero output from headphone jack also is also turned off.
Manual does not have any help on this topic.
I tried to search the forum, but may be I did not put the right words. Point me to the thread if it already discussed.
post #2 of 6
Using the DVD player the sound does not shutoff, using a input source the sound does not come from the speakers when you plug in the headphones.
post #3 of 6
Thanks for the reply Bud - but what do you mean by using an input source ? Using another DVD player or video source? First, it defeats purpose of having onboard dvd player and then I can connect audio from that input source directly to my headphone or speakers. No need to connect audio to DV10. Am I missing something?
post #4 of 6
just open the projector, find the speaker, and cut the wires... problem solved.
post #5 of 6
Think I would try to fabricate some kind of switch iffen ...
post #6 of 6
Try using the optical out.
