Just a quick question.
I have read that you can attach your walls directly to the Dricore. I was wondering this: If you attach your walls to the concrete and then lay Dricore with the 1/4" gap, would that allow some sound isolation (i.e. vibration) from the rest of the house? The gap created would be covered with baseboard for asthetic purposes.
Thanks for any reply.
