AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › Tosh HD-A2 HD DVD - First End User Reports!
Tosh HD-A2 HD DVD - First End User Reports! - Page 174
post #5191 of 5303
The 4.0 update will have all of the other updates included. I have updated the firmware sveral times and I'm currently running the 4.0. I have never had any issues with the player.
Good luck with yours!
R7
post #5192 of 5303
Originally Posted by Jim McC View Post
I recently bought an A2 with 2.7 firmware. If I go directly from 2.7 to 4.0 will it include all the upgrades in between? Or do I need to do each one separately? I have the discs from Toshiba, but I don't want to do them all if it's not necessary. Thanks.
The answer is yes, it will include all of the upgrades. It's like any software upgrade in that regard.
post #5193 of 5303
Thanks guys. I'm not having any problems, I just thought it should have the latest firmware. 4.0 will be the final upgrade then?
post #5194 of 5303
You only need to load the latest upgrade. I upgraded because a couple of movies would not play at 2.x.
post #5195 of 5303
Each update is considered comprehensive by Toshiba, but that doesn't mean that everything that ever worked will still work !
post #5196 of 5303
I had the same experience. I had some playback issues with a couple of discs and upgraded to 4.0 via the net and have (knocking heavily on a wooded object) zero issues.
It could be the placebo effect, however I think the player is more responsive to the remote commands and the load times have gotten slightly faster.
I'm glad I upgraded.
RTROSE
post #5197 of 5303
I have been having issues with SD dvd's freezing up on me. I downloaded 4.0 and I'm still having the problem. This is only happening with SD's. I am using component cables not hdmi. HDVD's are working fine. Not sure whats up.
post #5198 of 5303
Not that it would make a difference but is there a way to try the HDMI out to see if it is happening with that output as well? Try changing the output resolution to see if that works. I have some of my SD discs that when they start to play the message comes up that the higher output is not supported and says only 480p is supported. Then when I check both the player and the tv tell me the output is 720p.
Sorry there is not much else I can suggest.
RTROSE
post #5199 of 5303
What is the recommended setting for "Black Enhancement", On or Off?
I'm using the A2 with a Mits. HD1000 projector, which doesn't have the darkest blacks. Thanks.
post #5200 of 5303
I think I read somewhere it was best to leave off due to what is called "crushing blacks" or "black crush". I'm not sure exactly how to explain what that is but my best advise is to try it both on and off with the same sample material to see what is acceptable to your viewing experience.
RTROSE
post #5201 of 5303
RTROSE
As long as the projector is able to accept StudioRGB rather than just PCRGB brightness levels, there should be no crushing. I always use enhanced in my setup in order to get the best picture (doesn't cut off the below-black information). If you don't know for sure, all you can do is try it both ways and see which picture looks the most natural (particularly look for black detail -- make sure your test disc actually includes black detail, some don't).
post #5202 of 5303
I thought the consensus was Enhanced on for Component and off for HDMI. Or do I have that wrong?
John
post #5203 of 5303
I guess you go by consensus, I go by what works best with my equipment. Enhanced is definitely on with my HDMI (and component, and S-Video). My displays accept StudioRGB HDMI and enhanced gives me all the black level information the recording provides.
post #5204 of 5303
____________________________________________________________ _____
I don't know about the Studio RGB with my projector. I have the Mits. HD1000.
post #5205 of 5303
Then it sounds like you have a projector question, not an HD-A2 question. I suggest checking the manual and perhaps checking the appropriate projector forum. Or you can simply play with the setting and decide which mode pleases you best with that particular projector.
post #5206 of 5303
Tried but there's an error on the screen like no server found (not exactly sure what's the actual message ) but when I checked my modem and connected it to my PS3, it's fine. Have issue online as well extracting the file from ISO image to CDR but my software aint compatible so all that stressed and 3 babies crying at the same time ( 4yr old son, 2.5 yr old princess and a 10month old destroyer... SUPERDAD here) got me to call the customer service for the upgrade disk sent to me.... WTH....save me the stress.
post #5207 of 5303
Still says a lot for Toshiba to send out update disc to users when their format "lost" the war but they still hang in there to support the customer.
RTROSE
post #5208 of 5303
Hi. Trying to get caught up here. Is the 4.0 upgrade still the latest version? Also, the ONLY HD title I own that won't play in HD-A2 is 'Sky Captain & the World of Tomorrow' Won't load. HD-A2 displays an error message. Anyone owning SCATWOT have any luck with the upgrade? Thanks.
-Mike
post #5209 of 5303
What is the specific (exact) error code displayed?
I'll look it up.
post #5210 of 5303
-Mike
FWIW -- 2.7 works fine with every HD DVD title I've tried so far, including Sky Captain.
post #5211 of 5303
I have the D2 which is the same as the A2, anyways I am trying to play Troy with Dolby TrueHD but it seems that it doesnt send the TrueHD signal to my receiver, Denon 2809. It just sends it as a normal Dolby Digital sound...
post #5212 of 5303
Boy, I still have a lot of HD DVD titles but I sold the player back in late 07. What do you guys think? Is it better to buy another player for the 20 or so movies I have.....or to spend the money re-investing in BR versions?
post #5213 of 5303
Anybody wanting to replace Warner Bros. HD DVDs with Blu-ray versions... go to www.red2blu.com
You send in the cover art for Warner titles you own and for $5 per disc plus $7 shipping for the entire order they will send Blu-ray titles and you keep the HD DVD (minus the cover art, though many color printers will copy the cover art for you). There are excellent deals on multi-disc sets also... the 5-disc Ultimate Matrix set is yours in Blu-ray for $20 plus the cover art from just Revolutions (you don't even have to own the box to get the whole Blu-ray box) similar deal for Harry Potter boxes.
post #5214 of 5303
-Mike
Any errors I ever got were fixed by deleting the data for that movie from the player's memory and trying again. I guess if it gets corrupted the disc won't load as it thinks the save data should be loaded first. Hope that helps.
post #5215 of 5303
I'll check it out.
post #5216 of 5303
The HD-A2 can't bitstream the HD audio codecs. However it will internally decode the DolbyTrueHD. What you want to see on your receiver is multichannel PCM. I can't remember the exact settings, i'll check tonight unless someone else posts before me.
post #5217 of 5303
So, what are the best audio settings for the A2. I just picked up an Onkyo HT-RC160 receiver, and was wondering what the best audio settings were to utilize the HDMI connection (Auto or PCM). If I'm using only HDMI, does it matter what I set the SPDIF connection at?
post #5218 of 5303
HDMI on Auto will give you the results you're looking for.
And no it does not matter what you set SPDIF to if you are using HDMI only.
post #5219 of 5303
Much appreciated, JoergerMeister!!
post #5220 of 5303
WOW! I had no idea so much info existed! I have had a HD-A2 for a long time. I have had no problems with it at all. Never even knew about updates. I will try to figure out which version I have. It's probably the oldest!
BS
  Back to Forum: HD DVD Players
