The Tosh decodes the bitstream internally and outputs raw PCM. You should get uncompressed PCM 5.1. Not sure why you're only getting 2.0 (maybe a setting in the player or the receiver is defaulting to 2-ch mode).
What I'm not clear on is what the Tosh does for DD+ EX soundtracks (I have a few HD-DVDs that cite this). Do we get 5.1 and engage the EX processing manually in the receiver or is all the EX encoding lost?
PCM, LPCM, Bitstream, etc., and which connection to use (HDMI or Optical, etc.) I could simply use an optical cable to send the audio to the Marantz, as I did with my old Onkyo non-HDMI receiver, and "settle" for DTS.
avid
