pcgeek: do you mind posting your new settings?
just bought this from costco.com when they had the $400 off. the delivery guys brought it up to my 2nd floor bedroom (pleasant surprise).
so far I have very mixed feelings about this set. compared to my mits 65411 (crt rptv), it has the usual adv. of plams -- brightness, uniformity, no convergence issue. bright outdoor scenes and sports look good. sd looks better. But the mits is better on everything else -- movies and TV shows in hd.
though it can occasionally look great, the set doesn't have that "looking thru a window" feel you supposedly get with plasma (i have fios tv which is supposed to be among the best cable/sat source you can get; using both hdmi and components for testing). it's sharper than the mits, but the sharpness feels artficial. whereas the mits sharpness feels like a well focused photo, the philips sharpness feels like someone takes a pencil and draws outlines around objects. too much grain in dark scenes!! I did not know what pople meant by clay face til now, b/c people's faces almost always look off, like it's plastic and not skin.
I'm sitting about 7-8' away. yes i know, too close, but I sat at same distance with the 65" mits.
my settings:
cont: 70
brt: 48
color: 55
tint: -10
temp: normal
dnr: min pixel+ on dyn cont: min color enh: off active control: off light sensor: off
I know contrast is way too high, but it looks very dull at 50 or below. I'm very careful about black bars and static images so hopefully no burn in. and what is with the tint? I have no idea. I usually leave them at near 0 but that seems to be the best w/ this set. I have yet to do a proper calib with avia or dve, only the test patterns on hdnet, but so far these settings are what look most right to me. I'm hoping I can get the settings better.
edit: reread my post and I sound quite negative. sorry I'm just being honest. I'm just being the usual AVS obsessive type
my settings:
cont: 70
brt: 48
color: 55
tint: -10
temp: normal
