Originally Posted by zork52
HP,
So I gather you switch back and forth depending if the disc has the TrueHD and DD+ encoding or just the standard DD and DTS?
My B+K is a pre/proc. I guess I would have that same option using the 2 methods of connection somehow...........I"ll have to check that out.
I would still think if I've calibrated my system already I should just be able to connect it up and go, except have to turn up the volume for movies???
Or is it that the player is like the processor all unto itself and "doesn't care" what my pre/proc has the speaker levels ( including sub ) calibrated at?
HP,
I switch back and forth just to listen and appreciate the qualitative difference between the two. My regular listening though is always with the analogs - DD+/TrueHD. Of course as you know the optical will only pass a DTS signal doesn't matter if the track is in DD.
Since I don't have a pre/proc I can only tell you what I do and once calibrated that's it. Through analogs I calibrated with the separate multi ch input levels on my Yamaha receiver. The analog processing of the receiver allows, speaker size, bass cross-over, speaker db level including sbwf level. All these are available on the A1 but are limited and not well implemented as noted various places on this site. That means my Yamaha receiver overrides these adjustments.
On the optical side, since the A1/A2 passes a DTS signal through that input and since it's on the digital input side I can apply whatever processing available to the DTS such EX/ES processing to make use of my center rear speaker, etc.. None of these adjustments effect the analog levels through multi ch input..
. More realistic soundstage, better clarity in sound, better defined surround actitivty, etc. No problem with low-end response after I dialed in the sound levels with AVIA and a SPL meter.
