AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Used Outlaw 1050, or NAD T753
post #1 of 2
Putting together a small 2nd HT set-up. Only buying used gear, quality of sound being the focus. Any other suggestions, again my set-up will be used equipment? Budget is under $400.
post #2 of 2
There is a 1050 (and others) on audiogon. heres the link:
http://cgi.audiogon.com/cgi-bin/srch_fs.pl
good luck
