Ok, here is the final set of covers unless someone finds something that needs to be fixed. They are broken down into four sets depending on if you get the 12mm cases which I believe go up to 3 disc cases, or if you get the 14mm 6 disc cases that were bought in the group buy. The 14mm case is slimmer than the Blade Runner/Lost style disc cases so a new set will have to be made to accomodate the wider spine if that is needed. A few minor changes have been made since I last posted any images which include product ID #, some adjustment on where some things are, and changed text for Season 4.
Each set contains all the Seasons, BSG Razor, and the Season 4 variant covers that either mention Razor or doesn't mention it depending on how you want to create your sets. For those who don't want UPCs on their covers, I have made both 12mm and 14mm cases where the UPC is removed and replaced with another scene image.
Please let me know if anything doesn't work or needs to be changed. Hopefully this is the last time I need to spam the thread with images. I have not tested the 14mm covers with an actual case yet since mine haven't arrived but I did apply an extra 2mm to the spine in Photoshop. I have all covers in PSD format and can easily port them to any other image format that may be needed. Covers are at 3184 x 1800 resolution for the 12mm and 3208 x 1800 resolution for the 14mm cases.
Here's the download with the previews below of what they all look like. Each set is a RAR that contains the six covers that apply to which set you get.
12 mm Single(or Double or Triple) Case Set12 mm Single(or Double or Triple) Case, No UPC Set14 mm Slim 6 Disc Case Set14 mm Slim 6 Disc Case, No UPC Set
Here are what the final versions look like. I've only posted the wide versions since they're the same but the spine is just wider than the slim versions.
Season 1
Season 1 No UPC
Season 2
Season 2 No UPC
Season 3
Season 3 No UPC
Season 4
Season 4 w/ Razor
Season 4 No UPC
Season 4 w/ Razor, No UPC
Battlestar Galactica: Razor
Battlestar Galactica: Razor No UPC
- Edit (8/16/09 6:30pm)
Fixed the covered up 'y' problem in the Season 2 covers
- Edit (8/16/09 10:55pm)
Fixed wrong id # on Season 4 14mm covers, preview is still wrong but image is correct in rar.
-Edit (8/17/09 1:25pm)
Fixed wrong title Islanded in a Stream of Stars on Season 4 cover, preview is still wrong but image is correct in rar.
