Originally Posted by BallsDeepX
All of a sudden Infraview stopped printing my covers properly. Its cutting off the left side a little bit, a little more than 1/4 is being cut off. I did get a new printer but not sure why this would effect how Infraview. Any ideas?
In the preview section of Infraview its showing it properly but when I print its cutting the left side off a little bit.
This is for Blu-ray covers, correct? If it were DVD covers, I would say each printer can have a slightly larger or smaller printing area.
Are you using 8.5 x 11? Do you have larger paper, to see if it's the paper size with your new printer? Or, maybe your printing size could be adjusted. If it's "letter", change to "A4."
I just started printing covers, and my printer does the same as yours with DVD covers, a little less than 1/4 inch missing. It just barely fits a blu-ray with 8.5 x 11 paper. I'm glad because I bought my photo paper just for a few Blu-rays I wanted.
You could also try undercoverxp, and see if that helps. That's what I use.
