AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Purple Snakes, Magenta Banding on Panasonic Plasmas
Purple Snakes, Magenta Banding on Panasonic Plasmas - Page 26
post #751 of 772
if you actually have the problem, yes. it would display regardless of digital vs analog inputs.
post #752 of 772
Originally Posted by fahertyps View Post
I'm glad I found this thread. I was searching on flesh tones, etc to see if anyone else was experiencing the problems I was with the purple, pink, gray tones on faces, white and beige backgrounds. I have a 5 year MACK warranty. Anyone had any luck getting this covered by them?
I have a TH-50PX77U.
Update: I called 6ave.com and registered my complaint with their service department. I'm told I should hear something from a local repair shop within the next day or so. I thought it odd that their "Senior Corporate Service Manager" had not heard of these problems. He says they will need to run a "auto-generator pattern" and it is most likely one of the two "boards" that is bad. We'll see...
post #753 of 772
6ave.com finally found a local tech that would come out. He said he had never seen this happen before. It fiddled with adjustments on the set and said he could tell that all the boards were working properly. He wrote it up as "Low gas & Bad plasma screen". His comment was the screen or entire set would need to be replaced. Now I have to wait and see what 6ave will do under the extended warranty. --Hoping for a new set!
post #754 of 772
mine (10UK) was diagnosed as a "defective panel" also. my tech (who did know about the "snakes") insisted this is a different problem than the original "purple snakes" of the 60/600 models.... and it does look a little different than what I had on my 600U (or what I can now see on my friend's 9UK).
typically, it is cheaper for them to simply swap out with a new set than to replace the whole panel. In all likelihood you will get a replacement with an "equivalent" new model.
post #755 of 772
Trying not to get my hopes up too high...but that IS what I'm hoping for. I think the TC-58S1 is about the same price as what I got my 50PX77U for. Maybe...
post #756 of 772
it won't be based on cost, so you won't get a free size upgrade. rather, it will be based on finding a "comparable" replacement set which would be another 50" model, but likely 1080p (since that is standard nowadays). The "S" series is probably most comparable to the 77U. If you can talk to the field service rep you may be able to finagle it where you can pay the cost difference between 50S1 and 58S1 and upgrade.... can't hurt to ask!
post #757 of 772
Wow, I'm really surprised that this is turning out to be an ongoing issue with newer Panny plasmas. Originally, it was supposed to be isolated to the 6/60/600 series. I had my 600u replaced under warranty almost 2 years ago now with a 42pz700. I can honestly say, I still have not seen any signs of the 'snakes' or 'ants' like I had with my original TV. It still looks great. I think the problem is much more isolated now, otherwise, we'd be seeing a lot more complaints about this issue. With the 6xx series, it was almost guaranteed that you'd see the problem.
post #758 of 772
I do believe the guy that, at its roots, it's a different issue; the symptoms (misfiring pixels coming out purple) can be similar but it doesn't really look the same. I was over at my friend's the other day (he has a 9UK with clear "snakes") and we watched the Dark City blu-ray, snakes everywhere on green/gray backgrounds and sometimes people's faces, looked exactly like I remember with the old 600U. When I got home, I popped the BD in to re-watch some scenes on my 10UK and it was definitely different. I still got purple pixels and some "smearing" at contour edges but it wasn't quite the same thing.... clearly a problem, but definitely not as severe as on the 9UK/600U (or the photos in this thread).
I do think that specific problem was isolated to those 9G sets. The rare occurrence on a newer set seems of different origin, more like the occasional defective panel, some horrible false contouring artifact gone wrong... unfortunately I got nailed twice . I've stared at a lot of other Panny plasmas (both in stores and at friends/family's houses... my parents have a PX80U, my brother has a PZ80, my friends have PX77 and 50PX1) and have never seen it elsewhere. Either way, as long as Panny takes care of their customers, which they seem to do, I'm OK with it.
post #759 of 772
How can Panasonic possibly "take care" of a customer who's set begins to exhibit these things, which should not ever be happening, say a year after the warranty expires? An $1800 TV should not be deemed by Panasonic to be "unepairable" and disposable when only two or three years old. That is unacceptable.
post #760 of 772
So, 6ave.com called today and I was glad to hear that they plan to replace my 50px77u under the extended warranty I purchased from them. They were going to give me a tc-p50u1 but I pushed for the anti-glare coating that my 77u had and they said they would ship me a 50x1. Hope I make the right decision. ?? It seems to get better reviews than the 50c1. Unfortunately an upgrade was not an option.
Oh, yeah, and they told me just to dispose of the old set. Any ideas on what i should do with it?
post #761 of 772
I have a TH-50PX75U bought in Nov 2007. We started noticing purple snakes pretty badly since few weeks back.
I called up Panansonic from office and opened a case. The rep said I should call back when I have access to TV.
But in the evening I went back home and i am not seeing it. Has this happened to others? Will it come back soon? will keep updated.
post #762 of 772
Could this be magenta banding on my 54g25 plasma?
post #763 of 772
I have finally seen the "snakes" on my old TH-42PX60U.
But it is only obvious when I'm watching material that is standard definition wide screen that I have zoomed to fill the screen. Sometimes the snakes are more entertaining than the show I'm watching.
post #764 of 772
I have a friend that has this problem on a TC-P42U2. The unit is still under warranty and is in the shop for service. The problem is that it's been in the shop for over 30 days at this point. Instead of just giving her a new display, Panasonic has her waiting for a back-ordered "A" panel. Can anyone make any suggestions on getting this situation resolved in a timely (from this point forward) manner, other than having the back-ordered part miraculously show up? Is there a means of contacting someone further up the food chain at Panny? Thanks for any suggestions.
post #765 of 772
finally found a thread discussing this. i started noticing these "purple snakes" probably within the last year.
i thought it was something with the calibration got screwy but its still there.
so i guess there is no fix for this issues? is it just due to age and a bad design?
do the 2011 panasonics exhibit this problem too?
post #766 of 772
My in-laws have a TH-42PX6U and it has this problem. I noticed it several months after they bought it but that was years ago. No one seemed really bothered by it and I was nevery over enough to care.
Now we are staying there while our house is renovated and I've got to get this fixed. I think it was a Costco purchase. I applied a firmware update but it did nothing. I read through about 20 pages of the thread and I'll go backwards through it to see if there is a fix that was released in North America. I think half way through the thread was still early 2007...
Is Purple Snakes the right way to describe it? Took me a while to find this thread. Probably a few months of checking here and there before landing on this.
post #767 of 772
there is no fix.
post #768 of 772
Yeah sorry - no fix that I am aware of other than replacing the TV with a new one. Panasonic eventually replaced mine.
post #769 of 772
Panasonic replaced mine too, with a different Panasonic which had crappy picture quality when displaying SD material. Two years later, that one developed a power supply problem... $500 to fix. My solution: spend $700 on an LG plasma, and never looked back to Panasonic TV's. The LG is drop-dead gorgeous, better than my first Panasonic before the purple snakes, and the LG's allow you to adjust the color palette to perfection.
post #770 of 772
Interesting that this pink issue goes back several years now.
post #771 of 772
that's what happens when time goes forward, the issue gets older.... it would be more interesting if the issue suddenly became more recent!
post #772 of 772
I am surprised the Panasonic purple snake issue still exists! My th37px60 did it when I first got it Feb 2007, and I noticed a lot of people had the same. I complained to the Panasonic shop where I got it, and they came and put in a new D board. Been fantastic picture since. Its clocked up 11000 hours, according to the hours meter, and still going strong. Others complained too, and they also got a new D board.
