AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › Remote control codes...Not available?
post #1 of 3
I am trying to reduce my number of remote controls so that I can use mostly my Cox Digital DVR remote. I need the codes for the OPPO 971H and the ONKYO SR-TX504. I can't find them anywhere online. Anybody know these codes? Or do they vary depending on your universal remote?
Scott
post #2 of 3
Scott
You should be able to get your remote codes from www.remotecentral.com
I saw the oppo there. And if they don't have the onkyo exactly, most likely
one of the other onkyo remotes would work that are close to it in series number.
buz
post #3 of 3
bump for wanting same info
Onkyo 504 with Oppo 970/971.
* I tried remote central, but that site is way too hard to navigate.
  Back to Forum: Cable, Digital Cable - Non-HDTV
