Originally Posted by
Dougmeister
krkaufman
I've modified my universal remote and XBMC keymapping* to provide quick skip (30-second skip ahead) and instant replay (8-second skip back) remote functionality.
* due to a current XBMC bug where the SmallStepBack value is doubled when activated, I also needed to set the advanced setting to 4 (seconds) to get the desired 8-second jump.
can you point me to any directions explaining how to do what you did with your remote?
Actually, the defaults should work for you, except, possibly, for getting the length of the "instant replay" just right. The skip-ahead, by default, is the
right-arrow navigation button and is set to 30-seconds; and the "instant replay" button is the
'Back' button... but it may jump double what you want (14-16s), if the
submitted bug is not yet fixed. (I haven't tried the last month or so of T3CH builds.)
As for getting the "instant replay" just right, you can use the
advanced setting to tweak it. For example, assuming a fresh
advanced settings file (i.e. .../UserData/advancedsettings.xml),
which you may need to create, the following content would customize the "instant replay" setting to accommodate the bug (i.e. 4x2=8):
.../UserData/advancedsettings.xml :
p.s. If you want to change which buttons control skip-ahead and "instant replay", you can edit the
keymapping file (i.e. .../UserData/keymap.xml) and reassign the
StepForward and
SmallStepBack actions, respectively, within the device settings for the window section. For informational purposes, here are the default settings (as of 6/30)...
Code:
StepBack
StepForward
BigStepForward
BigStepBack
SmallStepBack
OSD
OSD
CodecInfo
Info
AspectRatio
Hope this helps.
