Originally Posted by
elevine
Any thoughts or suggestions will be appreciated.
Gene Levine
Hi Gene:
I can offer my TWO CENTS worth of help.
I use to have a 2307CI with a HD-A1.
It worked fine with my CRT Displays and my Sony Ruby.
Just this weekend - while configuring a new setup here - I ran into a HDMI
Handshake problem where there had been NONE before. This is with one of
my SONY HD-DVRs. Guess what I found was the PROBLEM?
A bad HDMI Cable. And STRANGELY enough - I got a GREAT High-Def picture
on SOME Channels and HDMI Handshake errors on other channels. I assumed
it was because some high-def channels and even low-def channels where sending
out some HDCP info. CHANGING the cable made it all WORK.
If you have any spare cables - give that a try.
BOTTOM LINE - your problem does sound like a HDCP handshake issue with
some piece of equipment.
I'd also try to run the HD-A2 directly to the Sharp - just to see if the handshake
works OK in the configuration. ONLY A TEST!
