OK, this one is driving me insane.
I have an 8300HD hooked up to a Panny plasma via HDMI with Cox Cable. Every time I turn off my display, the STB reverts to 480i and I have to do the setup wizard all over again which is annoying as all hell. I called Cox support and they basically said I was out of luck and would have to set it again every time (big surprise there).
I've been searching for a solution to this for over an hour now. I've found several instances of other people having the same problem but not a single solution.
Can anyone help or at least point me in the right direction?
If it makes any difference:
* I have 1080i, 720p, 420p widescreen, and 420p standard selected in the wizard
* Auto-DVI/HDMI selected in Picture Format in settings
Let me know if any other details are needed as I'm not sure what's pertinent here.
Thanks in advance!
Groov
Thanks in advance!
Groov
