AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › JL Audio Fathom 12" Sub
JL Audio Fathom 12" Sub - Page 9
post #241 of 402
did someone mention once that they thought the f112 was a bit more "musical" than the f113 ?
post #242 of 402
F112
21 - 119 Hz (±1.5dB)
-3 dB at 19 Hz / 150 Hz
-10 dB at 17 Hz / 167 Hz
F113
20 - 86 Hz (±1.5dB)
-3 dB at 18 Hz / 127 Hz
-10 dB at 16 Hz / 154 Hz
The F112 is flatter to higher frequencies than the F113. Whether that makes it more "musical", I don't know, but it should blend better with speakers that have higher -3 dB points, (which, I know, is not your situation.)
I know that my dual F112's are *very* musical blended with my Atlantic Technology 8200e's, (-3 dB @ 60 Hz.) I have been listening to a lot of DVD-A/SACD and the bass lines never sounded so good! No tubbiness, boominess or overhang, just clean tight bass with every note distinct and clear. (I am using Audyssey MultEQ XT with them and the ARO is disabled, if that matters.)
Craig
post #243 of 402
Originally Posted by craig john View Post
F112
F113
20 - 86 Hz (±1.5dB)
Craig
cool, thanks
post #244 of 402
All I can say is Awsome! I have had my F112 for a couple of months now and can't say I have owned a better sub.
WW
post #245 of 402
The F112 pair arrived today after their long journey from Florida. My dealer delivered them and they (thanks to JL's excellent packaging) were perfect. I set them up as planned with the F112's in the front of the Room and the F113's in the back. I am running each pair as Master/Slave and did a quick ARO on the F112 pair (the F113's were already done). Then, I took a look the the SMS-1 graph and did some EQ there.
First impression is very positive. I played some music and watched the first monster chapter of Cloverfield (great bass movie!) and already I know this is going to work out even better than I thought it would. The bass in my HT is simply the best I have heard. Still much testing positions and tweaking to do but for me, quad subs is the way to go.
Here are some pics.
F113 & F112
EQing
1st SMS-1 graph
Finished (for now)
post #246 of 402
Man, that is such a sweet setup!! What I would like to know, if you get the chance, is how much of a difference do you hear between the F112 pair vs the F113 pair.
post #247 of 402
niiiiiiice, the f113 brought it's little bro to the party!
post #248 of 402
Looking good Rob. Headroom galore judging by that FR graph.
post #249 of 402
post #250 of 402
Thanks homies,
Really haven't done an A/B comparison but as advertized they seem very close performance wise. With the different positioning in the room (F112's are 14' from LP, F113's are 7') it would make a comparison difficult.
As John mentioned, I now have lots of headroom. The subs seem to be literally idling though the most difficult bass passages but I will be tweaking/testing them further in the next couple of weeks. I was hoping having the F113 pair near field would increase the tactile bass at LP and it has. Me thinks that even with less capable subs, this type of deployment would yield very good results in most rooms.
post #251 of 402
With that much headroom, one other configuration worth trying consists of stereo front subs with an LFE mono pair. Whether or not it improves sound quality depends on room acoustics and your ability to blend the stereo pair with the mains and mono subs. Its a more challenging and time consuming proposition than quad monos since you have to struggle with more phase issues but the FL subs have plenty of controls to tame that beast.
The usual argument about this setup is you can lose the main advantage of quads, smooth FR across all seats. However that doesn't need to be the case if you are successful with placement and integration. The reward is a more holigraphic front soundstage with music and more realistic panning effects in movies. I've found the usual remark about how bass below 80hz is omnidirectional fails to encompass our survival ability to sense the direction of change in sound pressure. That's why stereo subs sound so much better than dual monos if properly setup.
post #252 of 402
Very nice RMK, what a sweet setup...
I'm gunna go sulk in the corner, seeing as I only have 1 F112... but then again, its just for my little bedroom setup..
post #253 of 402
Good suggestion and sounds interesting but I will have to hit the books before jumping into that one. Have you done this with your dual F113's with the SMS-1 in the chain? I'd be interested in a connection diagram.
post #254 of 402
Rob, I've planned the same thing as John is talking about. Connection to the front fathoms via xlr for ht. Connect via rca to integrate with the stereo part of things. Might be a pain in the butt to switch connections but at least it will let me try it out.
post #255 of 402
In addition to Asher's approach, there are several ways to do it. To help with integration I like to use another crossover to the mains like a dbx or rane with the LF running to the subs and the HF back into the main amp. Or if you have a powerful HT amp, run full range L/R to the mains and sub, and use the Fathom crossover to fill in beneath the mains. The external crossover saves amp headroom for the mains and allows a higher crossover point.
Funny signature Asher.
post #256 of 402
Hey congrats Rob and welcome to quad land. Nice choice with the JL112s but I had you pegged for another pair of JL113s.
I've been running dual 113s with dual Velo 18s for a while now and you can't beat the extra dynamics and headroom that the additional sub pair brings to the party.
Looking forward to your pics and impressions. Are you going to try and set up the JL112s in stereo or go with quad monos?
John,
In terms of articulation and precision, how does the 113 compare with DD-18?
post #257 of 402
Originally Posted by mpedris View Post
John,
That's an open ended question that has evoked at least half a dozen long threads. One of the earliest and best comparisons was the one that RMK and Ransac did, in December 2006 as I recall, which was followed by many similar discussions throughout early 2007. I would suggest reading several of those threads. The comparison usually involved a long discussion about music vs. HT, output, linearity, distortion, ARO, built in SMS, servo control, size, WAF etc.
Anyway, after listening to both for over a year, I'd still say they compare so closely to one another in terms of articulation and precision at normal listening levels that I have no clear favourite. Looking at graphs many would tempted to give the edge to the FL113 for HT applications because of its significantly greater output in the infrasonic. However that output comes with far higher distortion below 25hz compared to the servo controlled DD-18. Similarly its been suggested that the incredibly low THD of the DD-18 gives it an edge in precision, however the difference in THD which is mainly second order is not audible. Once the rooms transfer function is factored in, and equalized for using the ARO or built in SMS, it again becomes a toss-up except in intense movie scenes. But then again those scenes are not about articulation or precision.
Bottom line for me is they are both excellent highly articulate subs and too close to call. Because the compliment each other well either one would be a terrific addition to anyone owning the other.
post #258 of 402
What he said
The DD-18 though a much older design, doesn't give up anything in terms of articulation of bass notes to any sub I have heard. Also, I believe that due to the driver size, the DD-18 has a little something extra in the tank for the 40-50Hz impact bass in movies. On the other hand, the Fathom(s) have amazingly powerful and clean output for their size. When you have multiples of subs, size will be a factor in most rooms.
John's combo of dual 18" Velos and dual F113's is the best of both worlds IMO.
post #259 of 402
Thanks for the feedback, John, RMK.
If the 113 is comparable to DD-18, which DD would the 112 be comparable to?
How might the 112 stack up against the Velo SPL series? Again, which one?
post #260 of 402
I haven't heard the other DD subs but I can say that in by brief expierence with them, the F112 and F113 are very close performance wise. If I were to venture a guess, I'd say the DD15 would be comparable to the F112.
My first sub was a Velo SPL 1200 and although it was a nice little sub, it's not in the Velo DD nor Fathoms class.
post #261 of 402
Agree with Rob. Judging by the specs the DD-15/FL112 should be close sonically to the larger models in the product line. I've heard the DD-15 but not the FL112.
post #262 of 402
Any news on the f212?
What I would really like to hear is a JL tower with a 12" woofer, a couple of mid drivers and a smooth tweeter. It seems like a next logical step. Oh yeah, in tiger ebony.
Paul
post #263 of 402
Well they should have some bookshelf sized speakers coming out pretty soon I hope. They are being very tight-lipped about it.
post #264 of 402
Where's the best place and PRICE to buy the f112? Please PM me with some prices.
Thanks!! John
post #265 of 402
Found out what I needed. Thanks guys.
post #266 of 402
The "Twins" are on the way!!! Feels like Christmas
post #267 of 402
Very nice, be sure to report back with your impressions.
post #268 of 402
Yes, please report back your impressions.
post #269 of 402
If anyone, and I repeat ANYONE! is thinking about getting the JL sub,
GET IT!!!
All I did is unpack, place, and enjoy!
I will do the set-up latter but had to listen to them now and I tell you if they get any better than this, I'M NOT LEAVING HOME!
post #270 of 402
Hey RMK, so if someone walked into your home, took your F113s and replaced them with F112s, how long would it take you to notice the difference?
