Originally Posted by
doctorj
2. It is going in family room where it will see many hours of use. That's what turned me off from rear projection.
I don't understand this statement. Is your concern bulb replacement? Otherwise if the PQ of RP didn't turn you off, that might be your best bet.
doctorj
4. I really don't want to go less than 50". The only LCD I've seen that come close to the 50" Panasonic plasmas as far as price is Sharp's model. Maybe I've missed some?
I suggest LCD or RP, just making sure you get one that does not show motion blur to you. But they're pretty pricy in the 50+ range.
Note that my family has no idea what IR or BI is & I am stopped being anal over it after the first week. They treat the plasma as they treat the LCDs as they treat the CRTs. I've had no problem with IR. My wife insists on watching 4:3 content streched (no sense paying for that big screen and not using it she says), so I'm a bit ahead of the game there.
Be aware that some plasmas have a dynamic side bar that changes intensity to match what is on the screen. This will allow you to watch 4:3 in it's original aspect ratio and not worry about IR/BI from side bars. Make sure you view these in the store prior to a purchase though as some find them distracting.
BTW, the reason I recommend LCD or RP is your 3YO. I suspect that cartoons are going to be a family staple for a while. I also suspect that much of the time the tv will be viewed with a lot of ambient light in the room. I also suspect it will be about another 5 years before you can reasonably expect your child to turn off the tv/dvd player when leaving the room & not leaving the DVD menu up for 8 hours at a time. In another 5 years, you'll likely be eyeballing a bigger/newer/better display anyways.
