Hi all,
Just had the TH-42PX60U delivered and am running the break-in DVD (gonna take me a while to relocate my satellite coax so I can hook up the box near the new location of the TV....i.e., the opposite end of the living room). Have a couple questions.
1) Was looking into the rev of the firmware on the TV using the faq at BruZZi's Forum. Checking the TV, I see the following in the about section:
TV 0142-0110
Status 1 01F00-90000
Looking at the second, fourth and seventh values, I come up with:
TV 1.21
Status 1 1.09
In BruZZi's example, both of his numbers match. Is that always the case? If so, what's the story on my pdp?
2) Looking at the Panasonic firmware page, I see 2 files for the TH-42PX60:
Digital Tuner Firmware v1.04
DG-Board EEPROM GenX Firmware v1.25
Questions are...Do I need both (seems the version numbers correspond to the TV and status 1 revs) and if I do, do they need to be done seperately? That is to say, do I need to put one on the SD card, do the upgrade, then go back, delete it off the SD card and put the next file on, and do the 2nd upgrade? Or put both on at once and the pdp will let me pick which one I want to upgrade?
TV 0142-0110
TV 1.21
Status 1 1.09
