I have a 42" 720p plasma I typically view from about 6ft. No problems there with detecting "pixelization".
My next upgrade will be to a 50" 1080p screen with expected viewing distances of about 7-9ft. But I wouldn't hesitate to do 5.5 feet from a 50" 1080p screen either.
Don't think you can go very wrong with either resolution or screen size from the 5-6ft. distance, but still always advisable to check out a bunch of panels at that same distance in store to see for yourself. Your eyes might be more discriminating. The so-called grid-like "screen door effect" between the pixels is likely to be the only potential issue with a 42" 720p viewed from 5ft. Some can see it from as far back as 10ft., others not until they get a few feet from the screen.
