It is a nice sleak remote, and for the small cost it seems to be the way to go.
Quick question - I would love to be able to customize the "picture" and "sound" buttons... but they are not re-mappable are they...
complaints:
I can't say I love the stupid "wizard" style set-up interface
- I sure wish it was more "advanced" or at least had a more advanced option...
I had a hell of a time figuring out that I needed to increase the "repeater" to get my Pioneer 4360 to switch inputs when I changed activities... It wouldn't change to my cable box (SA 8300HD)input from the DVD player (OPPO 971H) because the TV was too busy syncing after changing res from the DVD player, and would miss the input comand...
It feels like there is a small motion sensor/ball bearing in it, but it doesn't light up when I pick it up, so I guess there isn't one...?
more later - but I needed to post something after spending almost 2 hours controlling my frustration and keeping from smashing it, while reprogramming it again and again... before FINALLY figuring out the issue.
complaints:
