AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Difference between BenQ W10000 & W9000?
post #1 of 15
I've read that the W9000 is a lite version of the W10000 but you wouldn't know it by comparing features at BenQ's global website. Anyone have a clue about price & features?
http://www.benq.com/products/Project...&page=features
http://www.benq.com/products/Projector/?product=992
post #2 of 15
There was a bit of confusion in the other thread because BenQ kept switching specs around on their page. The best guess that I can offer at the moment would be that they are using a different kind of DLP chip (Originally BenQ said it was using a DarkChip2 DLP but then removed it to just say DarkChip) , because all of their listed specs and features listed are pretty much the same:
http://www.aboutprojectors.com/proje...2/prodid2=4793
So it's hard to say what the real difference is at this point in time.
post #3 of 15
The difference is W1000!, I know.
post #4 of 15
An important question in this context is whether they will process a decent HTPC signal (i.e. 1920x1080p@24Hz), all Benqs have been reported to be a little 'stubborn' in this department (I remember a very disencouraging test by Andrea Manuti).
Any info on that?
post #5 of 15
Any info on that?
I think the guy had a lemon. I have the PE8720 (which was being reviewed), and it has no problems whatsover with a PAL signal. I have been enjoying this unit for more than a year now, and it still throws a great picture
post #6 of 15
Originally Posted by DaveMoi View Post
and it has no problems whatsover with a PAL signal ..
Okay, but that is not nobel price material either, being able to process PAL. The question is (esp. for the new Full-HD-PJs), can it do native/pixelperfect/48Hz or 24HZ or 24sfp??
post #7 of 15
I'm wondering if you read the review I wrote.
You seem to talk with an (apparent) lack of information: if you try, only try, to read the review (http://www.htprojectors.com/htprojec...=253&PROD=3057) you will find a lot of details about what happened during the review.
You'll read that I saw at least 2 PE8720 in Greece that were giving a very good image and wrote this.
This was not the case for the 2 (two) samples I reviewed.
I've published many photographs about this, for the exact reason that people like you, who don't know me, can have FACTS to see what happened and why I wrote my consideration. I try to speak with facts and numbers (please check the data I posted, i.e. firmware and configuration under test); and, what is more, I would never infer (i.e., the special implication of drawing a particular inference from a generalization conclusions from my peculiar experience.
The fact that YOUR unit is performing very well is, apart a positive fact for you, doesn't mean that EVERY PE8720 carries the same luck.
The difference between you and me is that I received the unit from BenQ Italy as 2 samples to be reviewed. And what you can read are the actual and exact results, along with the distributor comments at the end of the article.
May I know if you actually read my review?
post #8 of 15
Anyone know something about the W9000? IMO it may be the closest match to the upcoming JVC RS1.
regards,
Li On
post #9 of 15
Sounds like it is just the same projector but maybe with different model #'s in different countries. Also, here is the answer to the 1080p 24fps question from the Benq website.
"The W10000/W9000 is one of the very few projectors fully supporting the 1080p/24fps standard, for HD video at 24 frames per secondthe format for professional movie filming, production and editing, and used in Blu-ray disc players. Now you can have it in your home, the same high-quality video professionals work with."
Mike
post #10 of 15
Hm, why would you say that? Or would you also say the same thing about any other 1080p DLP like the HD81 or the SIM2 D80?
post #11 of 15
Because of the price. The HD81 is at $10k which is quite a bit higher than the JVC. I don't know the Sim2 D80 and I doubt it's price is close to the Benq.
regards,
Li On
post #12 of 15
Well, the D80 is around 6.750 Euro excl. VAT at the moment in Germany which is in the same region as the W10000.
However price isn't everything i guess
post #13 of 15
6750 Euro is close to US$9k, right? That's the HD81 range. I thought the W10000 is at $6k or lower.
I think we all agree those 1-chip 1080p gives a great picture if one don't suffer from any DLP mental illness! The upcoming JVC needs some competition!
regards,
Li On
post #14 of 15
I read your review of the 8720, let's hope the 9000 and 10000 work as planned.
k
post #15 of 15
Hi all.
I realise this is an old thread now, but I have a W10000 on my shortlist, should a 2nd hand unit become available.
My old W5000 was just untouchable for sharpness, thanks largely to its .95" chip.
The W10000, with its unique 3cm Darkchip3 should be a good deal better again! (right?)
One question I have is with the lens throw.
A 2.4 metre-wide image @ 3.6 metres throw is no-go in my room.
Has anyone tried (or heard of anyone trying) the lens mod to achieve greater zoom range?
If so, how much more range do you get?
Thankya kindly in advance...
