AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › Tosh HD-XA2 1080p HD DVD - First End User Reports!: USERS ONLY PLEASE!
Tosh HD-XA2 1080p HD DVD - First End User Reports!: USERS ONLY PLEASE! - Page 8
post #211 of 4604
Originally Posted by tsx500 View Post
if i use my current receiver and run all of the audio thru 5.1 analog, will i be getting the best audio quality (including Dolby TrueHD when available) this way?
Yes you will!
post #212 of 4604
Let me get this straight (with the XA2). I have yamaha 6090 with LPCM (multichannel PCM) and I cannot get TRueHD over HDMI (1.2A) connection but only the stupid two channel PCM (over HMDI)? Or do i have to resort to analog which by-passes my Yamaha's processing and get low bass? Thank sukkss
post #213 of 4604
You can get multichannel PCM audio over HDMI. You cannot ship TrueHD over the HDMI cable to be decoded in your processor, but that doesn't really matter since the DVD player will do it for you.
post #214 of 4604
Originally Posted by calikarim View Post
Most amazing player, get 1080i over component, but not via hdmi converted to dvi on my Mitsubishi 65813. I have an XA1 also with some connector no problem getting 10801 over hdmi, or upconverting standard dvd.
My only problem is hd dvd is ok over component, but i can't convert standard dvd to 1080i, serious problem. A lot of people are complaining about the A2 same problem, with hdmi to dvi getting 10801 it reverts to 480p
Please help
Hi,
Just to clarify, currently your HD-XA2 will not provide an image from your Mitsubishi HDTV via an HDMI to DVI connection, but the same Mits will output images via HDMI to DVI on your HD-XA1? Correct?
With regard to the "A2 same problem", I have been reading about several folks with A2s connected via HDMI to DVI running into downrezing problems, but they still get an image. If I understand you correctly, your problem is that you are not getting any image from your HD-XA2 via the HDMI to DVI connection. If so, that is a different problem than the HD-A2 problem.
The reason I am trying to clarify this issue is because I have an HD-XA2 connected to an InFocus ScreenPlay 7205 projector via HDMi to DVI, and I'm not getting any image whatsoever. Component video works fine.
Larry
EDIT:
I see that I misinterpreted your posting. I got my answer in an other thread in which you said:
My only gripe is over hdmi/dvd to my Mitsubish 65813 it downconverts everything to 480p, for SD dvd's and hd dvd. I only get 1080i over component only for hd dvd. I cannot watch any sd's upconverted to 1080i. I have an XA-1 and using same hdmi cable or component i get 1080i over hdmi for both HD dvd's and SD dvd's. There is a problem with second gen players and hdm to dvd's many people have complained about this with the A2.
post #215 of 4604
Originally Posted by spa View Post
Many people have HDMI to DVI working just fine. HDMI to DVI will lose blacker than black and whiter than white, but many displays do work with it otherwise. My panasonic plasma does, for example.
Those who have the problem are obviously waiting for a FW fix. A recent poll showed that a significant number of those using DVI saw the problem, but still less than half.
Hi Steve,
I have read about some folks with HD-A2s with HDMI to DVI connections having blacker than black and whiter than white problems, but so far I haven't seen reports of this with the HD-XA2. With all these threads it's possible I could have missed the reports. Can you please provide a link to a report regarding this problem for HD-XA2s?
I've seen the poll regarding HD-A2s with HDMI to DVI connections having a downrezzing problem, but haven't seen the poll for HD-XA2s with color problems. Can you please provide a link?
Larry
post #216 of 4604
Wow. Is the M1->DVI adapter active or passive?
larry
post #217 of 4604
Originally Posted by LarryChanin View Post
Hi Steve,
Larry
Nope, can't point to a case where it's been seen on the XA2. I assumed that it had, but now that you mention it I don't think I've seen one either.
Good question to ask people here: anyone with HDMI->DVI losing BTB/WTW on an XA2?
post #218 of 4604
I've gone through this thread but have not really found anything that would tell me if this is worth 2x the price of the HD-A2. I'm looking for something to hook up to a new 52" Aquos 1080p and would like to know if I should get the Xbox add-on and wait for prices to drop, get the HD-A2 if the pic quality is close to the XA2 or spring for the XA2 because it is that much better?
Any advice would be appreciated!
post #219 of 4604
Originally Posted by Josh Z View Post
For theatrical features, yes. However, some special interest content such as A View From Space With Heavenly Music or Guitarscape Planet was originally shot on 1080i HD video and is encoded on disc as 1080i.
Hi Josh,
Thanks, I've been wondering about this.
How about animated movies, would they be encoded on HD DVDs disc as 1080i/60?
How about most prime time network TV series broadcast in HD, are they likely to be mastered in 1080i/60 and encoded on HD DVD boxsets at that resolution?
The subject of whether ALL HD DVDs are encoded at 1080p/24 came up in a discussion where we were wondering how professional reviewers test new HD players. Assuming that there can be either film-based or video-base content encoded on HD discs, then would the reviewer need test discs authored in both resolutions in order to accurately evaluate the scaling and deinterlacing performance of a player for the appropriate content?
We know that most HD DVD have more than one resolution on a single disc, i.e. 1080p/24 for the movie and 480i or 480p for special features. (I'm not referring to Combo discs.) Is it likely that the special features could be in a different HD resolution than the movie portion?
Larry
post #220 of 4604
larry
Hi Larry,
As far as I know its a simple passive adapter.
Before the HDMI ouput on my HD TiVo failed (if worked for several months) I had no trouble sending HDMI to DVI to M1 to the projector and displaying a great image. In fact I even had a DVI switcher in the video path with no problems.
I suspect I'm dealing with a Toshiba to InFocus handshake problem, not a cabling adapter problem.
Larry
post #221 of 4604
Originally Posted by jlee301 View Post
I know a new firmware is not out yet. But I am getting "Cannot find out server" which is telling me either something is wrong with my player connecting to the network or the out server it is referring to is not available yet.
Are others getting Firmware is up to date message?
I am also getting this on the HD-A2. I tried every ethernet setting before calling Toshiba. Since there is no firmware upgrade for the A2, we did not pursue it. However, I still need to resolve this problem for the future.
post #222 of 4604
The A2 does not have 6ch analog output for audio. If you don't have a HDMI receiver or pre/pro you can't get decoded "hidef" audio stream. You're stuck with whatever comes across coax/toslink. Not a big deal to some, but it is to others. Same goes for the Silicon Optix Reon video processor. These are the two biggest differences.
larry
post #223 of 4604
I don't know why you'd assume that an animated movie would be any different than a film feature.
Most primetime TV is shot on film. They may be broadcast as 1080i, but the original HD master tapes are likely 1080p.
post #224 of 4604
from VE. Thanks Robert!
The unit is much more solid than the A2. It has a nice brushed metal case with HD DVD etched in the top.
I have it hooked with HDMI to a Denon 2807 and then HDMI converter to DVI to a M1 converter into an Infocus SP7205, which is a 720P projector. It does not have any problem sending 720P or 1080i over this connection. While the picture the XA2 sends it great, it is no better to my eye than the A2 which was no better than the A1, both of which I have owned. Perhaps my eye is just not discerning enough or maybe I have just reached the limits of my projector. I hopethe latter is the case, because I have a RS1 on pre-order and hope to see a big difference with that upgrade. I have tried both 720P and 1080i and can't say I see much of a difference in either HD DVDs or SD DVD's. I was hoping I would see a huge improvement in SD DVD's over the A2 and A1, but again, didn't happen. The load times are pretty good. With a disc in, it's about 35 seconds to the HD DVD logo then another 10 seconds beforeit starts to play, so 45 seconds total. If the player is already on, it takes 25-30 seconds to start to play a HD DVD and only about 10-15 seconds for a SD DVD.
I don't think it passes BTB or WTW. Avia was useless for setting contrast and brightness, couldn't see the second bar.
Rewind and Fast forward are marginally better than the A2, not nearly as good as the A1. It works much better with SD than HD. With HD it pauses for almost 2 seconds and then is very choppy. Then it pauses again when play is pushed. At least there doesn't seem to be the two seconds of muted play that the A2 has upon resume.
Overall I have to say I am a little underwhelmed. I am hoping that it is due to my 720P display and that it will really shine on the RS1 with a 1080P input.
Most useless accessory: It comes with composite video and sound cables!
The box says " True Color Support over HDMI 1.3" which is not Deep Color. What the heck is "True Color?" Kind of misleading.
post #225 of 4604
post #226 of 4604
Hi Nash:
I just want to make sure I understand. The XA2 will decode True Dolby HD and pass it over HDMI to go to 6.1/7.1 channel set up on my Yamaha? Or since my yami has only HDMI 1.2A, I cannot get True Dolby HD over HDMI and have to resort to analog (6 speaker or 8 speaker?) multichannel input into my A/v receiver, which would mean, I could not control LFE or bass? Does that make sense? Also, does anyone know if Xa2 player has audio set up to control bass (LFE) output for analog?
post #227 of 4604
I, too, am looking for opinions from anyone who has actually compared their picture quality and can describe the visible differences. In all these forums, I only saw one brief comment (favoring the XA2 PQ), but that wasn't very convincing by itself. Maybe we'll have to just wait until we can see them in person ourselves somewhere ... like maybe at Robert's store.
post #228 of 4604
Just curious if anyone has had any problems with their units simply powering off in the midst of watching an HD-DVD. I got through about two hours of a movie (The Interpreter), and then had the unit just power off (almost like the plug had been pulled... i.e. not a "clean" power-down cycle like you would get from doing it manually). It came back up fine, but this same thing happened again, every 5 to 10 minutes.
I've got everything UPS'd, so I know I'm not fighting a power problem, and the unit was not the least bit warm, so I'm hard-pressed to believe that it is overheating (in fact, I was surprised that after being on for two hours, it almost felt like it had never been on at all... the box didn't really even feel warm).
So... again, I'm just wondering if anyone else has seen any oddball behavior like that.
(BTW, I loved the picture and sound quality, before all of this happened.)
post #229 of 4604
Hi Nash:
Multichannel PCM over HDMI worked in HDMI 1.1 or maybe 1.0, don't remember.
larry
post #230 of 4604
Got my player last night- fooled around with some. hooked it up real wuick via coax audio-sounded good but noticed I had to turn it up more than what i am usually do. I have a few questions hopefully that can be answered;
1) I am going to hook it up via analog outputs-do I leave it on bitsream? Not quite sure of the correct settings I should use. reading the manual I also noticed there are many audio tweaks (speaker settings etc) had anyone used these at all?
2) pictures settings: has anyone used these to any advantages?-say edge enhancement etc. just curious, thanks
thetman
post #231 of 4604
First the good news: The first disc I popped into the XA2 was my glitchy copy of The Matador, which takes a full 3 minutes to load in the HD-A1 and always catastrophically freezes at the same point on the disc. The XA2 loaded it in practically no time and all and breezed through the scene where it dies on the A1. Success! I'm loving this player!
Now the problem: I was testing a few discs and noticed that playback is sometimes jittery, as if the XA2 were dropping a frame here and there. Oddly, the problem is reproducable when you replay the scene. Two places this stood out:
- Chapter 2 of Mission Impossible 3, as Michelle Monaghan opens the refrigerator.
- The beginning of Serenity, as the camera pans up to reveal River hiding on the ceiling.
I tried both 1080i and 1080p output with no difference. This problem is not present on the A1 (which I verified immediately afterwards). Can anyone else please check these scenes?
post #232 of 4604
FWIW, running at 1080p, I ran through this scene and saw no issue with it at all.
post #233 of 4604
Hi Jason,
I also have an InFocus 7205. However, I have not been successful in getting an image over HDMI. Normally I use a DVI switch to connect DVI or HDMI video sources to my projector. I run an HDMI to DVI adapter cable to the DVI switch which in turn connects to a 9 meter run of DVI cable which connects to an M1 adapter at the other end at the projector. This works with an HD TiVo, but yields no image at all with the HD-XA2.
I also tried taking the DVI switch out of the video path. I used an HDMI to DVI adapter at the Toshiba which in turn connected to the long DVI cable and the M1 adapter. This arrangement also failed to provide an image.
Can you please tell me which version of firmware your InFocus is running?
The only other difference in our setups is that you have your HDMI first running to your Denon receiver. I have read other threads where folks using Denon receivers have resolved HDMI problems. If you have a convenient means of running your Toshiba directly to your InFocus I would greatly appreciate knowing whether this configuration works.
I just have an HD TiVo satellite receiver and a V Inc. D2 upconverting DVD player for a basis of comparison. I have always enjoyed excellent images from these devices. However, to my eye my recorded HD TiVo programs look significantly softer than virtually all the HD DVDs I have sampled. (I've only had the Toshiba for a few days haven't done a lot of sampling.) My D2 has always done a good job on upconverting, but generally most HD programs look better than upconverted DVDs. So it goes without saying that HD DVDs look much better than upconverted DVDs.
It takes me too much time to switch resolutions to get a good feel which yield the best image, 1080i or 720p output resolutions. Without being able to do an instantaneous resolution switch they both look the same to me.
I've got a 120" diagonal Stewart Firehawk screen in a total light controlled room. I sit at roughly 12 to 13 from the screen, depending on the amount of recline I have on the cinema recliner. How large is your screen and where do you sit?
Since my Toshiba's upconverting features current;y don't work on my setup I can't try a standard calibration DVD. I'm anxious to buy an HD calibration disc when they are available.
I didn't expect a "night and day" improvement on a 720 projector, but I'm satisfied that the HD DVDs I've sampled look as sharp or sharper than my current HD sources. No doubt your JVC projector will look noticeably better unless you're accustomed to viewing from a great distance.
Larry
post #234 of 4604
Last night was a good night. I received my 70"XBR2 and the XA2..WOOHOO!!
First I have to qualify my remarks so that the comments are not taken out of context. I waited forever to get an HD TV. I don't like digital TV. Even though it is clearer and the color is better, the macroblocking, pixilation and other digital anomolies really get to me.
Ok, first........I am underwhelmed with the results of HD TV. Everyone talks about POP and 3D. Well I see mostly squares of color that motion blur at the points of the show that are actually of interest. In other words, when you want it most, it's at its worst.
However, the improvement with the XBR2 was enough to push me over the edge. I still don't think its all that WOW, but it is a big step.
Finally the XA2. I only watched Batman HD and Gladiator DVD. Batman looked way better than my old analog 61", but not quite as good as I was hoping. Same with Gladiator.
In Batman when it starts off panning past the flowers looks absolutely horrible. But, as long is there is not fast action the picture is fantastic.
I had no problems with the XA2. It popped out of the box, COAX to receiver, HDMI to XBR2, click, click...zoom. It worked well for both HD DVD and DVDs. I have not tried CDs yet.
The sound was excellent after a good bit of configuring. I don't have the low volume problem being discussed, but I also am sending PCM, not Bitstream. Also, it's not over HDMI. I did the audio channel configuration by setting distance and using an SPL meter to get the levels balanced. Once that was done $$$$ it was great.
UMR is coming next week to calibrate the TV. So, after I get a chance to spend more detailed time with the TV when it is set up properly I'll come back with more information.
post #235 of 4604
Hi Nash:
You can use analog or HDMI multichannel. The XA2 can decode the new formats and ship them over analog or HDMI in multichannel format. It can also send those formats still encoded over HDMI - but you need a 1.3 capable receiver (with the right decoder) to receive them and decode them. It's just really a question of where you want the decoding to take place - and for the most part, it will make not material difference to the AQ. You should be perfectly happy with the Yamaha and the XA2 and receive full benefit of the new audio formats.
post #236 of 4604
A calibration disc should be first disc in a DVD player when connected to a new TV or vice versa. UMR will set you up. However, if he's coming over next week, make sure you leave the TV on playing something for 100 hours or so to make sure the bulb gets broken in before calibration. Also, cable/sat/OTA sources, even HD (can you say "subchannels"?) vary which can have issues that no amount of calibration will help. Although there are some very good HD and SD digital channels.
larry
post #237 of 4604
My XA2 began doing a high squeal noise tonite while watching a few movies. It started last night when I would have to pause Fearless. Then carried over to tonight. I am using COAX for audio. Anyway, I ended up holding power for 15 seconds to force a complete shut down. Then afterwards it began to work fine. I tested a few movies to make sure. Does anyone know if this will become a chronic issue? Is anyone else experiencing this issue?
post #238 of 4604
I thought if you use coax (or toshlink) that you set the audio on the player to bitsream, not PCM. I am just asking because I am also using coax for audio now-but I have it set to bitsream..is this wrong? I plan on using analog connections soon-do I set the player for PCM on this as well?
thetman
post #239 of 4604
Hi Jason,
Larry
Larry,
I'm fairly certain that I have the latest firmware on the 7205, I'll check it later when i turn on the projector and let you know. I have never had any handshake problems with it. I assume you read the manual and have switched the output to HDMI on the Toshiba? I made the mistake of switching the output to 1080P on the Toshiba. Lost the picture. The 7205 is supposed to accept some 1080P signals, but apparently not what the XA2 is putting out. I was able to remember the key presses to get it back to 1080i.
I am projecting onto a 110" diagonal FireHawk. I didn't expect SD to look as good as HD, but there are numerous posts saying that the upconverting of the XA2 makes for an almost HD picture. Just was hoping for a little more there. Like I said, hopefully it will do better with the RS1. Good luck with your M1 connection.
Jason
post #240 of 4604
Unfortunately, it's official, my XA2 has a serious judder problem on both DVD and HD DVD content. Nothing in the set-up can fix it. The clearest example of it that I've found is on World Trade Center at 3min. 48 sec. There's a shot of a pedestrian walking on the sidewalk, followed by a shot of traffic. Both judder like crazy, and the problem is reproduceable every time. Can anyone else check this?
My projector will sync to 48hz, and my default is to use my scaler's frame rate conversion to watch content that way, but the artifact stands out even more then. It's still visible at 60hz, but less so. This happens regardless of resolution output setting, and is present over both HDMI and component. The same discs play smoothly in the A1 under the same circumstances.
The audio is also way out of sync with the video, another problem I don't have with the A1.
  Back to Forum: HD DVD Players
