AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › Tosh HD-XA2 1080p HD DVD - First End User Reports!: USERS ONLY PLEASE!
Tosh HD-XA2 1080p HD DVD - First End User Reports!: USERS ONLY PLEASE! - Page 90
post #2671 of 4603
Originally Posted by bakpakva View Post
My XA2 arrived yesterday, and it also has a very noisy fan. I am wondering if there really is a chance that some units are quiet, or if they are being used in an area that masks the fan noise. My theater is dead quiet and I can easily hear the fan noise on my player. The small fan in back puts out a great deal of air volume, so my thought it that it is just the design and no amount of swapping players is going to fix that. I could be wrong, so if anyone swaps out and finds the noise goes away, I will consider giving it one more try.
Edit: As a reference, I measured the fan noise to 57 dB (slow C). This measurement was taken with the player sitting 5 inches from the wall in my rack, no disc, and sound meter held directly over top of the player and pointed at the back wall.
I can assure you that may XA2 is quiet and not masked by other equipment. 57db is quite loud jeez.
post #2672 of 4603
Just out of curiosity, what is the build date on your X2? Was it made in Japan or China? Mine was build July 2007 in China, purchased through Amazon. Also, when looking at the back of the player, there are 3 screws the appear to hold the fan to the case. These screws are located at the top right and left, and the bottom left. There is a screw hole at the bottom right, but there is no screw in it. Is that common or am I missing a screw?
Bsather, you are correct, there are only 2 screws that hold the fan, top right and bottom left. The third screw I saw was for the top of the case cover. It is tough to see with the player mounted in my rack.
post #2673 of 4603
Hello:
Mine is in a rack with an XBOX and PS3 (with a little fan added just in case) and I have my home server in the same area. All have fans going at one point or another so I guess I just never noticed the XA2's fan.
Given that some people have reported random shutdowns of their units (which is a sign of overheating) I am betting that the unit needs a good fan to keep cool.
If someone were feeling ambitious and the unit is hidden in a rack, I am sure the unit could be modded to remove part of the case and provide better cooling with a less noisy fan.
Splotto
post #2674 of 4603
Originally Posted by bsather View Post
Both of my XA2's were manufactured July 07 in China. Were the XA2's ever built in Japan? I know my XA1 was...and my Denon receivers...
One of my XA2's is very quiet....more so than the XA1 was...the other has a whine that can heard from 8ft.
I have the RCA model of the A1, and it is about as loud as my XA2. My RCA was build in Japan, so I just wondered if the XA2 was originally built there.
I tried loosening and tightening the screws on the fan, but it didn't really change the noise level. I just sounds like typical fan air movement noise to me with a touch of fan motor/bearing noise. Perhaps I was expecting too much, or there is a wide difference in fan parts. I will keep it a month and see if anything changes or someone finds a way to swap out the fan. It would have been nice if they would have put in a bigger fan like the A1 has, but ran it at a slower speed for the same air movement. The fan port size is much smaller on the XA2.
This is not so much of a problem when my projector is running, as it is much louder, but when listening to music it is distracting to me.
post #2675 of 4603
If the build date is on the back its gonna be a PITA to get to. Would it also be on the box? Ill take a look.
post #2676 of 4603
As a reference, I measured the fan noise to 57 dB.
My XA2's fan is truly inaudible. I have to hold my hand behind it to feel the airflow to know that it is actually spinning. Mine is also a July 2007 China-built unit. I guess I just got lucky and got a quiet one.
Given that (a) fans are el cheapo components of uneven build quality, (b) fans are easy to replace, and (c) noise seems a fairly common problem with the XA2, I would try contacting Toshiba customer support and asking if they could send you a replacement fan.
post #2677 of 4603
I cannot hear my XA2's fan either - bought from Amazon with a July 2007 build date.
post #2678 of 4603
For those who say they cannot hear it, does that mean from their listening position? I have decided I am going to give this player a shot because we have alot of ambient noise between heat going on and off, a nearby refrigerator, etc., it is seldom 100% quite in my listening area so I don't think my attention will be focused on the player. In the bedroom however, this could be more of an annoyance. My A2 isn't dead quite either but the XA2 for sure, is on the loud side.
post #2679 of 4603
I can sit next to it and don't hear the fan. Its a non issue on my XA2.
post #2680 of 4603
Mine was really loud and when I looked at it I saw a lot of dust collection. I wonder if these fans are vulnerable to dust. So, maybe people with dusty environments (wood or tile floors) are having more problems than people with less dust (carpet, etc). Could the sound be related to dust? I have to admit that a new, loud XA2 kinda breaks that hypothesis, but...
post #2681 of 4603
Hmmm, interesting, I can't hear mine unless I right next to it as it seems that quiet.
post #2682 of 4603
Can anyone hear spell quiet?
post #2683 of 4603
I don't sit near my unit, but I have before while it's running and have still heard nothing.
post #2684 of 4603
I think you mean here
post #2685 of 4603
I mean can anyone here spell quite?
post #2686 of 4603
My player was built in Jan 07, not sure of location. I'm too lazy to pull it out of the cabinet. I've never noticed any fan noise, but I've never specifically listened for it.
Mike
post #2687 of 4603
Fan? My XA-2 has a fan?
post #2688 of 4603
I received my XA2 Nov29 from Amazon and finally today I took it out of the box and I update the firmware from 1.5 to 2.7 using the CD I burned.
The procedure went smoothly and the whole process took 15 minutes tops.
I hooked the XA2 player to my Panasonic PT-47WXC tv through component inputs as this tv does not have HDMI outputs.
The player ran quiet. I guess I am one of the lucky ones not to get a noisy unit.
I also noticed the speed time to put a dvd into the drive was almost as fast as my Denon 1600 dvd player. There was no noticeable delay.
I going to mate the XA2 with a 57 MITS Diamond Series 833 DLP TV.
I like what I see so far.
KD ( A Canadian living in Arizona )
post #2689 of 4603
Originally Posted by dixlon View Post
[snip]
No delay? Huh? Just turning it on takes a while. Loading HDDVD is much longer than a normal DVD. It's pretty annoying, but I can get used to it I suppose.
Chandler eh? My in-laws have a vacation home near Chandler Fashion Square.
post #2690 of 4603
Funny you say that I'm going to the Chandler Fashion Square mall to pick up some Chinese food.
post #2691 of 4603
I think you mean quiet.
post #2692 of 4603
Let me guess. P.F. Changs? Nice food around there. Cheesecake Factory's nice too. And In-n-Out Burgers. Mmmm.... I really miss those In-n-Out burgers!
post #2693 of 4603
I have the A2 (MFR 3/07) and recently acquired the XA2 (MFR 7/07). I immediately realized that the XA2 was noticeably louder than the A2. I have a projector in the HT room that is of course louder but while listening to music with the projector off, the whine from the fan was immediately noticeable and somewhat annoying. I opened both players and looked at the fans. The fan in both players is made by Delta Electronics and share the same model number, DSB0512LD and are both 50x50x25mm in size. However, the fan in the XA2 is rated at 0.18A and the one in the A2 is rated at 0.09A. They are both 12V DC fans and have identical two pin connectors (I believe the 3rd pin in some fans is used by the board to determine/adjust fan speed in some applications). The fan in the XA2 seemed to push out more air against my hand than the fan in the A2. I swapped the fans in these two players and, as expected, the XA2 became very quiet, and the A2 became loud. I looked at Delta Electronics' site (http://www.delta.com.tw/product/cp/d...cfans_main.asp) in order to find these fans, but there is no model number that begins with DSB. Instead, they have a similar looking fan with the model number AFB0512LD. It is rated at 0.06A with a noise level of 25dB, and comes only in the 50x50x20mm size. I then found a post by an AVS member wherein he reported that the fans in the XA2 and A2 were made/distributed by Tranyoung with A2 having the 5025LL12S fan (8.35 CFM flow/14.5 dB noise) and XA2 having the 5025L12S fan (12.26 CFM flow/22.1 dB noise). These are also 50x50x25mm fans with 2 connectors. In calling around, I was told that it was not uncommon for some manufacturers to use somewhat different fans in any model player even in the same year of manufacture. This may well explain why some people here post that their units are quiet whereas others report the opposite. It is interesting that the Tranyoung fan in the XA2 pushes out 32% more air but at the expense of 500% more noise (7.6dB difference equates to 1.26 raised to 7.6 since dB is in log scale). If you do a search on the first PN (the quiet fan apparently in the A2), you will find that they correspond to Toshiba PN P000401260 with price of $38.19 and Toshiba as the listed manufacturer, and also PN P000477480 with price of $12.94 and manufacturer field left blank. I plan to test the temperature in the XA2 with the quieter fan from the A2 compared to the noisier fan it came with. DD and DTS decoders can run hot and the excess heat interfere with the function of the circuit board. It was for this reason, for instance, that the Lexicon RV-8 V2 units received a continuous fan and a new power supply as the overheating in V1 units (no continuous fan) caused erratic behavior in few units. My hope is that the quieter fan from the A2 transplanted into the XA2 can provide adequate cooling without causing any problems.
John
post #2694 of 4603
John
Thanks for sharing. Excellent post.
post #2695 of 4603
Excellent post ihifi! There does seem to be something going on with the difference in noise levels between owners of the XA2. It is either a fan issue, or as someone else has noted, it may be a transformer on the power supply. Either way, I am sure someone will get to the bottom of this and hopefully we can quiet the noisy ones down a notch.
I am still debating on whether to try a swap with Amazon once they have more in stock, or sending it back to Toshiba directly with specific concerns about the noise levels. The first is more of a crap shot and may result in the same results, the latter may have a better chance of success if Toshiba knows what the issue is and can implement the proper repair.
There is also the chance that some are just more sensitive to the noise frequency or their placement of the player amplifies the noise. Mine is in an open rack and the back wall may redirect the noise back into my listening environment.
post #2696 of 4603
Follow up:
There was a feedback left on Amazon regarding the noise possibly coming from the transformer on the power supply, rather than the fan itself. I actually tested for this possibility by unplugging the fan in the XA2 and listening for any noise from the PSU and elsewhere on the player. The player was dead quiet with the fan unplugged. This does not clear the PSU as the source of noise in other players but at least in mine, the source of the noise was definitely the fan.
John
post #2697 of 4603
Well after weeks researching these forums and other reviews from all sorts of "experts" around the internet, I decided to take the plunge into a stand-alone HD-DVD palyer to compliment my HT. I previously owned the 360 add-on unit.
My Current set-up is:
* Samsung LN-T5271F LCD Television
* Samsung BD-P1400 Blu-Ray Player
* Energy Take 5.2 Speakers System
* Onkyo TX-SR 705 (on order)
* and now...the HD-XA2 HD-DVD Player
I own over 800 DVDs and SD palyback is essential. I have a modest budget so I was not keen on spending retail so I took a gamble with e-bay.
won an auction @ $360 and crossed my fingers.
Out of the box, the player had 1.? FW and a terrible lip-sync problem. At first I thought I was suckered with a bad player, but I had read how the player suffered from this with early FW versions.
I quickly upgraded to FW 2.7 and did a quick test run of a few SD and HD-DVD titles. Here are some of my initial comments:
1. Lip-Sync is corrected. No issues w/ LFE and a full viewing of King Kong set @ 1080p/24 suffered no stuttering nor shutdowns as some have experienced.
2. I am a bit let down w/ SD playback. The main selling point I kept hearing was its "supposed" great HQV upscaling for SD DVDs. Well ( and I remind you only a quick run) I am not impressed. PQ of SD is NO better than either my BD-P1400 Samsung BR nor my Sony BD-S300. Maybe I need to see more tests or maybe I was expecting too much. I am not saying it looks bad...just NO better than what I have seen before.
3. HD playback is gorgeous. Nothing to jump up and down since I wouldn't expect nothing less. I like the piture tweaking options but need to learn more on what settings work best.
4. I Read all the stories and complaints about the remote...I don't share the same criticism. I like the backlit function so that is actually a plus for me. Either way...I use a Harmony 880 so the remote was never going to be a deal breaker for me.
5. Can't wait to mate w/ the Onkyo 705 and hear it's Audio capabilities.
as I spend more time watching, I'll share any issues with you. in the meantime, I do have a question for you.
q: why doesn't the front panel nor the box of this player have any branding/badging indicating the "HQV" chip? I notice that the BD-P1200 from Samsung has it, and th eupcoming Onkyo 805 does also. Anyone wonder why?
post #2698 of 4603
Originally Posted by CRIOLLO2MIl View Post
Well after weeks researching these forums and other reviews from all sorts of "experts" around the internet, I decided to take the plunge into a stand-alone HD-DVD palyer to compliment my HT. I previously owend the 360 add-on unit.
I have the XA2 and is currently my HD player. I also have the A2 on the HD side and on the BR side I have the 1400. The XA2 when using the picture functions from the remote make SD DVD's look quite a bit better over the standard out of the box setting and better than the A2 or the 1400. This is viewing on my XBR2 at 1080p/60. If your not seeing this, something is not right.
The XA2 attached to my Marantz SR7002 is trouble free and with the 2.7 FW the audio is fabulous you will love it.
I don't mind the remote and it can be used as a weapon should somone try to take my popcorn I also have the 880.
post #2699 of 4603
Humanoid,
what picture settings do you hve on the XA2? I still don't know what settings look best
post #2700 of 4603
I had the lid off my XA2 yesterday, and unplugged the fan. Silent. The Delta fan is definetly the whiner here.
Great news, and much easier to remedy than a power supply transformer. I would like to keep my XA2 in the rack, rather then hide it away under the cabinet like I did with the 1G player because of its fan noise. I concur that the rotational speed of the XA2 fan is much higher than the 1G which probably doesn't help matters.
  Back to Forum: HD DVD Players
