AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › Tosh HD-XA2 1080p HD DVD - First End User Reports!: USERS ONLY PLEASE!
Tosh HD-XA2 1080p HD DVD - First End User Reports!: USERS ONLY PLEASE! - Page 144
post #4291 of 4650
Originally Posted by Smarty-pants View Post
Digital Audio Out should be ON
That 's the one..... without out this set to ON you cannot bitstream out the advanced codecs.
post #4292 of 4650
Yes, Stevo, that was the missing part--'Digital Direct Audio Mode' needs to be 'On'
post #4293 of 4650
Are an owners having issues with bitstreaming DD+ to an audio receiver and getting audio dropouts? Particularly Pioneer receivers? Essentially sending the DD+ signal to the receiver for decoding and getting audio dropouts. Are any owners not having this issue where your X-A2 is bitstreaming DD+ 1.5 mbps Universal or Paramount titles to a Pioneer receiver and not getting audio dropouts?
post #4294 of 4650
I have an A1 and I would like to know if the XA2 can play video from the HDMI and Composite video outputs at the same time. My A1 will not do it.
Steve
post #4295 of 4650
I'm not sure if the XA2 will do it or not, but you do realize that if it does, it will have to be set to output 480i since that is the max res for composite video.
post #4296 of 4650
Smarty-pants,
Thanks for the response... Yes, I do realize it I have added a crt (single) tube in my theater. I just checked my A3 in my living room and it will do it. I will be looking for another A3 or if the XA2 can do it I'll be looking for one of those to replace my A1. The A1 is alittle too slow to put in the living room for the rest of the family.
Steve
post #4297 of 4650
Steve
Located behind the hinged lower hatch that hides the controls on the XA2's front panel, is a slide switch that sets its resolution range. If my memory serves me correctly, in one direction this switch shuts off the HDMI and Component outputs and activates the S-Video and Composite outputs. It's an either / or situation (either Hi Res / or Lo Res).
post #4298 of 4650
Audiodynamics,
Thanks for the response... I don't have an XA2 so I can't check it but the A1 is something like that I can change the v-output and resolution on the player but I have my player's audio out in HDMI and when I turn off the HDMI setting it also turns off the audio and I don't want to use the optical or coax anymore.
Steve
post #4299 of 4650
Is there a way to stretch a SD dvd picture on a 16:9 100 inch screen using the XA2? I'm using a projector and as of now I only get a 4:3 picture? On my Panny BD30 there is a function call 16:9 Full that fills the screen. Does the XA2 have a similar function?
Kirk
post #4300 of 4650
Kirk
The player will only output 4:3 regardless of its setting if that's the source. You would have to use a Wide Mode on the TV or projector itself.
Per the manual: "DVD video discs containing 4:3 picture only always display
4:3 pictures regardless of this setting."
post #4301 of 4650
Thanks for the answer to my question. I'm really impressed with the way it plays HD-DVD disks. Great player!
post #4302 of 4650
Yeah it's awesome for SD upconversion as well.
As an aside, I can override the 4:3 limitation with my TV, but am finding that as a "purist" who prefers letterboxed films it's kind of the antithesis to not view 4:3 as it was intended. So I hardly use stretch mode anymore. My .02 cents.
post #4303 of 4650
Agreed.
Also, the XA2 presents 4:3 material at a slightly wider aspect than 1.33. I've literally attached Post Its to my screen to compare the image from the same disc displaying 4:3 content via different players and the XA2's output is slightly wider. It looks closer to 1.66 to me.
Random: finally watched the terrific, HD DVD-exclusive J.J. Abrams/Tom Cruise PIP commentary on M:I:iii last night.
post #4304 of 4650
Hi,
After I recently played a DVD in my XA2, I opened the tray to remove the disc and I heard an odd noise (like plastic cracking). I took out the DVD and pushed the button to close the tray. The tray went in but the door did not flip back up. The door on my other unit has a lot of tension and closes easily. I can't see how this works from looking at the outside. Before I try to "fix" it (and open up the case), can someone tell me whether this problem should be easy to fix? It sounded like something may have broke, but I suppose a spring could have just come loose. Does anyone have any suggestions? Thanks,
Gregg
post #4305 of 4650
Looks like I have a little reading ahead of me tonight, just picked up one this morning. The used unit came complete with box and manual in flawless condition for $220. I feel a bit guilty about buying this since I have too many players however the price was too good to pass up. It's really built well and looks quite nice. Packed away the A35 for now.
post #4306 of 4650
You're going to like it alot. Check out the Picture Button settings to get a jump.
Picture Button Settings
post #4307 of 4650
My XA2 power cord has gone missing. Where should I start looking?
post #4308 of 4650
Isn't it just a standard power cord? I think the include a snap on ferret core, but other than that, it's just a regular cheapie power cord.
I know partsexpress sells those snap on ferret cores.
post #4309 of 4650
It ain't according to this guy. It'd be great if someone could confirm.
http://www.avrev.com/home-theater-vi...-player-4.html
post #4310 of 4650
Nah. It a cheapie figure-8 power cord.
post #4311 of 4650
You're right! Amazing.
post #4312 of 4650
Thanks for the tip. So far I've been liking the player. My collection of HD DVDs has dwindled during the past year but for $220 I couldn't help myself just to add in a good up-converting player. I'll have to make a decision whether to sell off the A35 soon.
post #4313 of 4650
Well I believe I have experienced my first "shut down" bug yesterday while watching the 12 Monkeys HD-DVD. It happen twice during playback. I don't recall the second time, but it first happened after about an hour. I initially thought I accidentally hit the power button but when it happened again, I knew it was something about the player.
I have about 20-30 HD-DVD titles that I have watched without incident and this is the first time I've had something weird happen with the player. The video output is set to 1080p/24 and I have v4.0 firmware.
Is there a known problem with the 12 Monkeys HD-DVD perhaps? I may test to see if the problem occurs at exactly the same point everytime.
post #4314 of 4650
My friend had the shutdown bug and used a workaround: Powering the XA2 up before anything else is powered up and so far it's worked out fine.
post #4315 of 4650
That's good advice and could explain why the problem only now surfaced for me. I recently changed Televisions and may need to reprogram my Harmony One to start the HD-DVD player first.
post #4316 of 4650
No problem playing 12 Monkeys HD on my unit, likely it is the shutdown bug as you thought.
post #4317 of 4650
I tried again yesterday and it played fine all the way through. The player was the first component turned on this time.
post #4318 of 4650
That's good news. These are awesome players but do have their glitches at times. Sometimes mine will switch the output resolution (with SDs) on me if I stop playback and resume, even though the setup menu shows it's still at 1080P.
I have to go into setup and change it to something else and then back again and all is well. However, I just bought the new Oppo BDP-83 BD player with the ABT 2010 VRS chip and will use that for upscaling SDs and save the XA2 for HD DVDs.
post #4319 of 4650
Same here. Love the BDP-83!
post #4320 of 4650
Wait...wait..the Oppo BDP-83 BD is available to purchase now?
  Back to Forum: HD DVD Players
