Originally Posted by
rdjam
Well - I think it's pretty ridiculous. If the PS3 could decode two streams at once and therefore be able to do PIP, and therefore be capable of being BD-Live compatible, then I think someone in the BD camp would be up here in a flash to tell everyone.
Well from what I have heard the PS3 is actually capable of decoding two 40 Mbps MPEG-4 AVC HP streams at once. Of course you may claim that hasn't been shown but we know for a fact that it can decode a 40 Mbps MPEG-4 AVC HP stream at 1.5x speed. Both of which are interesting since they would indicate that the PS3 is more than capable of decoding two video streams at once. Especially considering that the maximum combined video bit rate for both video streams has to be 40 Mbps or less.
rdjam
Therefore, I think it's a pretty well-founded conclusion to figure that the PS3 can't do it.
No offense but no only is that one of the poorest conclusions I have heard in a while but there really isn't any question about whether or not the PS3 can do PiP with Blu-ray. Of course it could. The question is when, or if you are very pessimistic if, that ability will be added to the PS3.
rdjam
If they had thought the whole thing through up front, there would have been no need to have two standards - the "second phase", otherwise known as BD-Live, is, IMO, a "tack-on" to try to match the features of HDi.
For what you consider a tack-on I guess beating HD DVD in terms of requirements is something that you simply consider a minor detail. After all Amir wasn't arguing against HD PiP on this forum for no reason at all.
rdjam
So here's what Bluray has ended up with - BD-J, in the currewnt Bluray players, is inferior to HDi.
Do you know for certain that anything that BD-J can do can also be done with HDi? If not than how can you possibly claim this?
rdjam
When I use the word obsolete, it's my opinion that it's pretty accurate here....
Technically speaking the PS2, Xbox, and HD-A1 are obsolete products but you know quite that people do not go by the dictionary definition of that word. You know quite well that when you use that word in your signature that people may not correctly understand what it means. As such you are going out of your way to deceive people about Blu-ray and defend that by saying that it is an opinion. Maybe so, but it still isn't a very honest thing to do.
rdjam
By the way - in the HD News thread, we've just found out that Disney has released Flightplan as a VC1 encode! And they say Casanova is next in VC1....
And BDboys said it wasn't true....
I don't remember anyone claiming that Disney would never start using VC-1 for their Blu-ray releases. Now if you think this news means that Disney is going neutral than you can have that opinion. Personally though I wouldn't get to excited about that since any studio can use VC-1. Even a studio exclusive to Blu-ray.
rdjam
They are certainly better positioned to release to HD DVD now, so that's good news for HD DVD also, IMO.
Exactly how does Disney using VC-1 make them better positioned to release on HD DVD? Also do you even know if the encoding that is used for Flightplan could be used for HD DVD?
