Which Megatouch
post #1 of 13
Thinking of getting a Megatouch for the gameroom but have a couple questions. First which machine do you feel is the best value for the buck? Secondly does anyone know of a list or table that lists all the various models and comapres them or at least the order of best to worst? The only thing close to this that I found was a document on the Merit site about upgrade paths but it's not very good at showing the different models. Thanks.
post #2 of 13
I don't own a Megatouch but I do own 2 different touchscreens. One is from a company called Uwink and has a LCD touchscreen similar to the new Merit Megatouch ELO models, etc. I also have a CRT based touchscreen from a company called JVL (www.jvl-ent.com). I recommend a LCD version but I like the JVL more because it has the iTouch 8+ software on it which has 100+ games compared to the 50+ games on the Uwink. Net Net, the Merit versions are nice (and the next purchase I would make) but I would get the LCD + a later version of software (Merit Force 2006 or later) that has 130 games or something like that. You could pick up a JVL Eclipse for aroound $2,600 which is the LCD JVL version and I think that compares to around $3,000+ for a similar Merit Megatouch. Merit seems to bring a little more of a premium due to it being the most sold brand. You could look at a older version though on eBay for around $1,500. Anything much less than that and I don't know if you will be as happy.
post #3 of 13
Well this is going to sit on a stand next to my slots and not on the bar so size isn't a big issue. I just don't think the premium you pay to get the LCD version is worth it right now. I was probably looking to get something in the MAXX range. I'm just not sure how all of the machines compare. On a side note. I wonder if anyone has ever thought of taking the guts out of this level machine and putting them in a smaller case out of site with a wire running to a third party LCD touch screen? I wonder if it's even possible.
post #4 of 13
Does anyone make Merit type games that can be run from an XP computer with a touchscreen? I've seen a few, but they are very basic and there were only a few games with each.
post #5 of 13
I looked at that idea also and found some but you just lose the refinement of the interface and not all of them are touch screen friendly.
Can anyone that has a megatouch tell me what kind of interface goes from the motherboard to the monitor? Is it just a normal monitor and serial interface?
post #6 of 13
Just anf FYI. I found someone on Ebay who is selling megatouches where he did exactly what I was saying. He relocated the insides into a pc case and is just using a LCD touchscreen for the display.
post #7 of 13
This link lists and has screenshots and descriptions for each model of Megatouch starting with the early XL models through the current Force models.
http://www.meritind.com/Service%20Ce...scriptions.pdf
I recently sold my Midway Touch Master 7000 which was ROM based and not upgradable for $350 on Craigslist. I bought a Megatouch Maxx (hard drive based) Ruby touch game locally from eBay for $400.
Here's the deal with upgrades. For $20 I could buy a Ruby 2 hard drive off eBay and install it in my Jade game for an easy upgrade and wouldn't need a new security key. If I want to upgrade to a Jade, Saphire or Crown edition, then I would need a hard drive AND security key for that model. A security key is not needed when upgrading within the same model (Jade to a Jade 2).
The Maxx cannot be easily upgraded to the Force models though. There are only a few games added to each upgrade (Ruby to Ruby 2, etc). But I plan to jump from my Ruby to at least a Saphire when I find a good deal. Right now I'm very happy with the Ruby games because they're all new to me and it's a big step up from a Touch Master.
FYI - Upgrade the memory in the Megatouch (most come with 32MB) by adding older PC100 memory. I had a spare 128MB PC100 module and it made a huge difference in the speed and smoothness of the animation. I especially noticed the high scores animations were sluggish before and now they are smooth as silk.
post #8 of 13
I'm looking for a jade key or a crown - let me know... I'm on Ruby 2 currently
post #9 of 13
Sorry to drag up an older thread but after looking for a Megatouch for a while I searching for info I came across this page that has been a great resource for me so I thought I would pass it on:
http://www.davemanut.com/info.htm
post #10 of 13
You had an interesting idea so I did ask this question to a guy on eBay that sells a lot of Megatouch stuff. Basically I told him I wanted to know if you could make a poorman's version of the new machine by taking a Maxx, hiding it under a bar or behind a wall and running an LCD to the mainboard connectors, he said it was possible but it would have to be a touchscreen that the software supported.
Mike
post #11 of 13
Mike
I actually saw someone on Ebay selling exactly that. I did take the LCD touchpanel that I use for my jukebox and hooked it up and it did work. Just never got around to doing the whole thing.
post #12 of 13
Very cool, looking at the parts inside the machine there really aren't that many if you are not concerned with taking money or using the OEM monitor. Just a couple of boards and a power supply.
Mike
post #13 of 13
It's basically a PC with a special security key
