Originally Posted by
Larry M
Cool! I think we have the same screen if you're talking diagonal size.
My 120" wide 16:9 (137.7" diagonal" EN4K screen came in last week. Masking panels are coming soon.
Now all I need to do it build a thater
Did you get the magnetic bar put in before the screen frame was shipped?
Can you post pictures of the panels?
I didn't know that the magnets needed to be put in the frame until after it was already ordered, so I'm thinking of ordering the friction ones from Seymour, because I can't get anything to fit properly since, as you probably have found out, the screen material is so tight to the frame that it is hard to get anything in between without risking the material, and the frame is tapered, so friction fit is tough.
