AVS › AVS Forum › Display Devices › CRT Projectors › Differences in Marquee Focus Yokes?
post #1 of 52
I've noticed that the internals of the Marquee focus yoke is sometimes different. Like my current 9ultra has the original red tube assembly and two new OEM tube assemblies.
The original red has a nice, small spot size. While the new OEM blue & green have a much larger spot size (yes, I've somewhat adjusted magnetics). In attempting to diagnose this, I've noticed that the focus yoke on the original red tube has it's internal windings protude further back than the internal windings of the OEM replacement blue and green.
post #2 of 52
I've never noticed this, but a bigger winding will produce a stronger field and "squeeze" the beam down more. I think that's exactly what the sony coils that CJ uses. I didn't know there were different OEM F-coils? When you say OEM replacement do you mean like "new" from VDC or NOS stuff off a dusty shelf?
post #3 of 52
IThe original red has a nice, small spot size. While the new OEM blue & green have a much larger spot size
The next time you see a bare OEM (VDC) tube, check out the amount of silicone that they put on the high voltage cup. Your original tube should have a smaller amount.
When I replace any tube in a Marquee, I always shave down that glue/silicone. If not, the focus coil may not move forward enough to get the best spot size. It is very important to be able to get the focus coils as forward as possible to the front of the tube, if not, you'll not going to get the best focus.
Pull the tube out and shave off the excess silicone, and in doing so you may shave off some of the cap as well. And that would be fine, because you'll get that focus coil right where it needs to be for the best focus. And after doing this, it may even do better than the original. But for sure it should improve the focus if done right.
And don't worry about it arching because you've remove a bit of the silicone and cap. There's plenty of silicone under that cap.
post #4 of 52
There is nobody out there who knows more about how to maximize the performance out of a Marquee than MP. If only there were 10 of him to travel the US and the world to work his magic on everyone's Marquee.
post #5 of 52
Dragan, it's one of the tubes from that big auction awhile back. Came complete with all the magnetics & plastic covers etc.
I've gotta digest what MP just said above. Though I did move the scan yokes as far forward as possible, then left just a couple of militeres of movement for the focus yoke adjusting. I didn't really go all out on it to see if it could be moved further.
Heading out the door now and will tackle this later.
The attached pic shows the difference between the red windings and green windings. It's a pretty clear difference!
post #6 of 52
hmmm, there is a BIG difference that's for sure. If those are the old 9" OEM tubes from Nevada then they could have older 9000 series coils on them. I know some/all of the coils were re-designed when the 8500 came out in 95. i'll have to look through my parts-bin and see what I can see?
post #7 of 52
Wow, I had no idea there was a difference between the 9000 and 9500 tube assemblies!
These were in fact the Salt Lake City tubes, and came with instructions for installation into a 9000. hmmm is right!
And to think that I sold off all my used 9500 tube assemblies. In fact, some of them were practically given away.
post #8 of 52
Yeah... I missed all that or I would have bought a bunch of em to have as spares.
post #9 of 52
Verified... there is definately a difference! I pulled the newer focus coil from my
red tube and swapped it over to the underperforming green tube and right away
my spot size got smaller!!!!
Prior to doing this, I took apart the two focus coils to see if there really was a
physical difference and there was. You can see the guage of wire is different.
Also, I measured and saw that the newer coil has more height to the winding.
[older coil on left, newer coil on right]
I was also curious as to how the focus coil is really supposed to be adjusted. This
always kind of confused me as everyone describes the procedure a bit
differently. The outer lid is basically 100% plastic. It merely serves the purpose
of holding the focus coil stationairy to the tube neck. And you can see the
difference in size between the wingnut bolt holes on the lid vs the body of the
focus coil.
Here is a better view of how the body of the focus coil is adjusted, while the outer
lid simply clamps onto the tube and is stationairy.
Here is the difference between the older (first pic) and newer label:
And afterwards I noticed this in the Marquee Training manual where it discusses
the basic changes from 8000/9000 to 8500/9500 models:
So if anyone has a couple of the newer Focus Coils (yokes) for sale, I would
definately appreciate first shot at them.
post #10 of 52
at first I thought the difference was that the the older coild didn't have the Zone Stig winding but it looks like they both do. So it's just a different design and obviously delivers a stronger EM field to choke the beam down to a smaller size. Very interesting, this info should be archived on Curts web-site. It's in fact very usefull for someone wanting to upgrade an older machine. I've always told people it's easier to just get a newer chassis than trying to find all the parts and these yokes even add to that long list of little pieces you would need.
post #11 of 52
Speaking of changes not commonly known: the splitter too has also been slightly changed so it should not be interchanged at random between the different models of marquees. It will work but beware. This is also a note found from a training ,anual.
post #12 of 52
igroucho - what has changed with the splitter and what differences would this make? I've tried using the splitter from my 8500 to trouble shoot before. Then got confused as to which splitter belonged where.
post #13 of 52
The splitter was changed along w the HVPS when the 8500 and upwards were introduced. This is what I picked up from a TM:
"A new low impedance splitter plus low impedance HVPS reduce the horizontal streaking significantly."
post #14 of 52
There may have been a splitter upgrade (I havn't read through all my data on these) from the 8000 series to the 8500/9500's along with the HVPS upgrade, but for any 8500 or 9500 the spitters should all be the same. I'll check on this later to confirm.
As for better upgrades to the later version marquees (8110, 8500, 9500). The real and true changes are in the software, with the exception of what changes were done with the Ultra's.
For instance, by replacing one chip on the CLM, you'll be able to change the focus start point to a 65% increase.
With that same chip upgrade, you'll also correct on the vertical sync pulse.
Plus with the right chip upgrade, you'll get individual focus for each memory.
There's other chips that will also effect different functions and ranges in the projector, and are listed as upgrades and would be found on later model marquees.
Another, the HVPS has been upgraded 2 times since they went to the 8110, 8500, 9500's (three versions of the 34.9kv).
post #15 of 52
Well CZ, if nothing else you've taken the price of new focus yokes from $50 to $100 in one post..
I don't have spares sorry! I've been using all spare F coils with the astig winding to convert 8110s to 8500s.
post #16 of 52
??? I guess I was just wasting time focusing each of my different sources individually? (MyHD at 1080i; satellite transcoded at 720p mostly but I have done others). I assume at least the convergence adjustments hold for each memory at least or am I off on that assumption as well (81110+ - some of us are slower than others - but at least now I may be able to find out why my blue focus spot is so much tighter than my red and green)
post #17 of 52
There must other significant magnetics differences as well, because the vertical height of my red 9500 CRT is much smaller than the 9000 series blue and green CRT's in the same projector. Even with convergence zero'd out and vertical height's set to 50 each.
Curt, thanks for checking though. Plus I didn't realize new focus yokes were only $50. I remembered that the deflection yoke is incredibly expensive and assumed the focus yoke would be expensive as well.
Mike, moving the focus yoke as far forward did help to achieve better initial focus... even though it was only about a milimeter that I was able to move it up. Thanks.
Ralph, the simple way to find out is to go into each of your recalls and set the focus (Pic, 4) to a different number and save. Then go back into each of your recalls and see if the focus number is still different in each recall. Btw, what Mike mentioned only applies to focus (Pic, 4)... it does not apply to the Service Focus.
post #18 of 52
OK - thanks but I am still a little slow on this. I never adjust the focus number - maybe I am out to lunch again but it seems like that was set to 50% and left it that way when I did the service focus steps. - But I did do those for each memory (input /recall-setup) - I suppose they (service focus) don't hold either, or there is only one?
post #19 of 52
Ok now I am a little confused.....
I have never been real happy with my focus and have been needing to get into my projector and do a real good setup since I swaped it over from a 9000 into a 8500 chassis when I ran across this thread. I went back and looked at the focus coils on the smoked 8500 tubes thinking they would be the better ones and I would slide them onto the 9000 tubes.... well they have totaly different #'s on them and look like the older ones pictured ref 21.695.01p type 9251.51 and n/s 50 F O
anyone want to take a stab at what I got and if its worth swaping over ? I am about to get into the projector now and see what is on the tubes now but figured I would post to see what I have sitting on these dead tubes.
post #20 of 52
Not sure if this would be of much help, but the coil in the picture is from a new tube assembly that was purchased from VDC not long ago (sometime last year).
post #21 of 52
Mike, your middle number seems as it would be compared with my third number.
N/S on oldest is___194 E 9
N/S on mine is____125 H 9
S/N on yours is__00236 K 5
The pattern seems to be the 2nd to last character. "E" being the known oldest, "H" being from year 2001 (my Ultra) and "K" from your current date VDC. Can anyone confirm this theory?
I wonder if there is any significant difference between my year 2001 focus coil and Mike's current year focus coil.
post #22 of 52
I'm confused about all this with these coils, and as I had indicated earlier, I knew nothing about a difference in the coils, and there's nothing in the documentation that i have that says that there is a difference in them.
In fact, on this past Tuesday while JBJR was down, I called a former Electrohome engineer and while I had him on the phone I asked about these coils. And from that conversation and what I was repeating back to him that JB could also hear, was that the only changes that he knew of was the change from the very early 8000/9000 to the 8500/9500 coils. He said as I had mention from my literature, that the main focus improvement in the later Marquees was in the software. That was any software (U35) version starting at version 4, which has several different versions of versions 4 (a, b, c, etc), to include version 4.4 Not sure what VDC now offers.
However, version 4 only work on the CLM in the Ultra's.
post #23 of 52
The only difference in newer focus magnets is the static gauss is very slightly different between the ones used on 8" tubes and 9" tubes. The mag is closer to the phosphor on 8" CRTs so needs to be a little stronger. Physically they are the same.
That N/S XXX is the serial number. Made in France so Number/Serial.
Scott
post #24 of 52
TSE, thank you for the info. It doesn't sound like there is any difference between the later model focus coils. Nothing to effect video quality or spot size anyway.
Btw, I swapped old vs. new style convergence coils today (red to green) and there was no appreciable difference. As far as I can tell, if anyone has an older 9000 style complete CRT tube... the only thing to change over to newer would be the focus coil. Nothing else probably matters.
post #25 of 52
Hello,
i have Focus Coils from a 8" 21.695.01P
and from a 9" 21.696.01P.
Yoke Deflection Coils from a 8" 21.691-01P
and from a 9" 21694-01P.
In the part-list are different numbers for the coils declared.
What's the difference?
Do 8" coils also work in an 9" CRT?
Tom
post #26 of 52
Originally Posted by tomson1973 View Post
Hello,
Tom
I know that the yokes on the 8" and 9" units have different part numbers, however, I have tested them in the past and could see NO visible difference and they work fine.
As for the focus coils, the VDC parts list from a couple of years ago list the SAME part number (21-696-01P) for both 8" and 9" focus coils.
As for Crazy Eddie's different "ns" numbers, I have fairly new coils on some 9" oem tubes that say: ns: 46 FD, 82 D9 and 83 D9. So what does that mean???
post #27 of 52
Best I can tell, the two D9's are fairly old while the FD is "I don't know". But I suspect it's newer than the D9's.
I think the [alphabetical] + [numerical] is an indicator of how old the model is. Like A1 would be older than A9. And Z9 would be the newest.
The D9's are 8000 or 9000 style focus coils if the schema mentioned above is to be believed. I would suggest you compare them with the FD or higher # to see how much tighter the dots get.
post #28 of 52
I don't know much about it, but, I know that they are "relatively" late 9500 coils and NOT 8000/9000 coils, since they don't have the stig winding like 8500/9500 do.
post #29 of 52
The coils that I started this thread over came on complete tube sets for the Marquee 9000, as per the directions in the box that it came in. There was no mention of 9500LC anywhere on the directions. And the coils did have the stig windings, though I never thought of this until you mentioned it.
So these may have been for very early 9500LC's. In either case, when I upgraded to newer focus coils, my dot size grew noticeably smaller.
This could be due to revisions, or perhaps renewed magnetic strength. I'm not sure. But I'd suspect it has to do with improved versions of the focus coils!
post #30 of 52
Btw, how are ya doing these days, Bruce? I don't see you on the board as much as in the last couple of years or so. Actually, seems that ever since the big FL hurricanes, you've nearly dropped out of sight!
  Back to Forum: CRT Projectors
