AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › PS3 owners on a budget, who want lossless HD audio - Look here.
PS3 owners on a budget, who want lossless HD audio - Look here. - Page 17
post #481 of 504
I was running my 360 through the 605 via component and the image looks much softer. I plugged it directly to my lcd (the digital optical out into the 605) and it looked a lot better and sharper. Does anyone have a softer looking image when it goes through the 605 via component?
could overheating degrade the PQ? I had the 605 in a tight unventilated space for a while but it never crashed.
btw, my PS3 and cable box runs through the 605 via HDMI and looks fine.
post #482 of 504
With your 360, what resolution are you outputting to the 605?
post #483 of 504
i also was curious if the HK 247 will do 7.1 PCM, basically what problems will i run into using the 247?
post #484 of 504
my 360 is set to 1080p My display is also 1080p
post #485 of 504
I have a 3.1 set-up (I just prefer it. The surround sound is loved by all, but it distracts me.) Theater Dimensional is enough surround sound for me, there are some (few) 5.1 tracks that I liked but the majority of them actually pulled me away from the movie. I use my old rear speakers in my bedroom now.
So I have my PS3 hooked up to my Onkyo TX-SR601 via optical, does this mean I lose the dedicated sub channel when I select PCM? What setting should I have it on to maintain the dedicated sub channel?
Please PM me if you know the answer to this one. I would really appreciate it and thank you in advance o audio master
post #486 of 504
Originally Posted by HijoDeDios View Post
but the SD channels aren't 1080i/p, they are probably 480, so would I then have issues?
If you connect your DVR box through HDMI it will be fine... the DVR box will be scaling them to 1080i/p anyways (just like before), so you won't get any scaling artifacts like you potentially could if you had to run it through component -> hdmi -> TV. You'll really have to compare it yourself, as there may not be any depending on your DVR's scaling and TV's scaling.
It will get scaled once from 480i/p to 1080i/p and just look kind of ugly (as SD tends to on HDTVs)...
I haven't noticed any ugly scaling artifacts from choosing 720p on the DVR and then having the TV scale to 1080p (outside of the ugliness of 480 TV being upconverted to 1080). I have my DVR going through component and have it running in 720p and then my tv scales to 1080p (my DVR's HDMI port doesn't work). SD Looks the same as it did before on my TV.
As far as 7.1 PCM, I think it supports it, but I don't think it'll allow you to run a 5.1 PCM as 7.1 PCM like many other receivers.
post #487 of 504
It'll send it as a 2.0 stereo. I'm not sure you'd necessarily lose everything when it converts it to 2.0 like you would if it did just take the L/R channels alone and send those, dialog would often be way too quiet and wouldn't sound right in that case -- I'm pretty sure it'll combine most of the sound information from the 5.1 into those 2 channels so your receiver should be able to pull out enough bass to send to the sub and dialog should sound okay. You'll have to do some comparisons to see what sounds better for you.
post #488 of 504
so basically my extra 2 speakers won't be in use unless I am watching a BD or playing a game on ps3 that outputs 7.1? is this something that could be changed with firmware or is it available in the 347 or any other comparable HK unit or would i have to look elsewhere, i just can't get over the aesthetics of HK units
post #489 of 504
Any more news on the horizon?
post #490 of 504
news on what?
post #491 of 504
I assume what most are hoping will eventually happen with the audio for bitstream of HD Master. I bought the Panny BD30 so I can wait. If not, I may eventually sell the PS3.
post #492 of 504
Actually, I need PCM over HDMI 1.1
post #493 of 504
If it is in your budget, it would be better to avoid the PS3 and buy a player that streams DST-MA and a HDMI 1.3 receiver. As the old saying goes, "a cheque in your hand is better than 2 in the mail".
Personally, I am beginning to wonder if we will ever see internal decoding of DTS-MA by any player including the PS3 (and not due to technical reasons).
post #494 of 504
Were there any new product announcements for reasonably priced receivers at CES?
post #495 of 504
Pioneer announced a few cheapies.
post #496 of 504
what about people who do not use a receiver, but just plug HDMI from PS3 to TV? They cant get lossless?
post #497 of 504
I am super super happy with my Denon 2307ci.
I have it hooked up to my Tosh A2 & PS3 and they both work great.
I got DTS sound out of The Simpsons Movie and it sounded great. But so far thats the only DTS movie i have watched yet.
post #498 of 504
might be stupid, but does your tv (when you hit the display button) show 1080p on your tv (when using the component to receiver setup)? what do you run from your receiver to your tv?
post #499 of 504
Go easy on me folks here... I haven't a bloomin' clue.
Anyways, I'm thinking of getting one of the these Onkyo TX-SR605 recievers (seems a good choice, no?). So how do I get this connected to my TV and PS3? Do I put a HDMI cable from my PS3 to the reciever and then a HDMI cable from the reciever to my TV?
What about putting my Wii and 360 into the reciever? Could I just plug an optical cable in from my 360 to reciever and it would work ok? Not sure if Wii supports optical so how would I connect that through component?
Also, what speakers would be recommended for said reciever. I'm thinking 7.1 here. Nothing to expensive but good quality all the same. Don't really like the long vertical types but whichever goes.
Thanks in advance for any help. It's worth 2 cookies.
Oh and try to keep it as simple as possible. I've got an headache just thinking about it.
post #500 of 504
Yep. That's how I have mine and it ....is.... AWESOME
Again, yep that's how I have my 360. For ps3 I use HDMI, for 360 I use optical, it works great. I don't own a Wii so I can't help you there.
I'll let someone else answer this. I bought a home theater in-a-box a few years ago (Onkyo) and while I like it, I think there are better options out there
It really is simple. That's the great thing about HDMI, it makes life easier IMO.
post #501 of 504
Now that the PS3 can decode DTS:MA by next week, I think this thread will have more relevance now that more users will be interested in the best 'bang for the buck' receivers.
post #502 of 504
All along I felt the thread needs a sticky.
post #503 of 504
Someone should do an A-B with the PS3. Without the full blown MA and then with.
post #504 of 504
I don't know why this thread is here. Except for the last page of posts it was active "pre-AVS cleanup" of HDM areas. There's no reason for the thread to be here. If anything, it should be in the receiver forum and "billyju(?)" just started a thread there. Or maybe the BD player forum. It won't be a sticky if it's PS3 only. Stickies are now only for common things for all BD players.
Please, can somebody do this: Start a new thread (not here if it's hardware related) and make a clear statement of what the intent is to be. Or just go to the Amps and Receiver's forum. Thanks.
larry
  Back to Forum: Blu-ray Software
This thread is locked
