This thread is dedicated to the owners of the E2000 series Sony LCD RPTV.
It is for discussion of The best settings and Service menu tweaks to get the most out of your new TV.
All other discussion about stands, picture quality can all be asked in The Official Sony E2000 series Thread located here: http://www.avsforum.com/avs-vb/showthread.php?t=687072
FAQ:
Q: Where can I find the operating Instructions for my TV?
A: Right Here
Q: What Resolution Is this TV?
A: 1280x720
Q: What is the best signal to send to my TV 1080i or 720p?
A: The best is 720p.
Q: What happens if I input a 480p or 1080i source?
A: The Tv's Scaler will take that Image and Scale it to 1280x720.
A#2: In the case of 1080i it will down convert the image from 1920x1080 to 1280x720, and for 480p it will upscale it from 720x480 to 1280x720.
Q: Should I buy and use an Upscaling DVD player?
A: If you can afford to yes, by using an upscaling dvd player you are relying on a different scaler than the one in the TV to output a signal and create a better image.
Q: Which upscaling DVD player is the best for this TV?
A: Almost everyone will agree that the Oppo 971 will be, it uses the Faroudja chipset and is region free and plays PAL dvd's !
Q: I still see black bars on my movies and my TV is 16:9 why is that?
A: Any move that uses a Scope bigger than 1:85:1 will use black bars to fit the image inside your TV, they are there to show the correct aspect ratio the movie was shot in.
NOTE: ALL SERVICE MENU ITEMS ARE DONE AT YOUR OWN RISK AND SONY NOR ANYONE ELSE IS RESPONSIBLE FOR ANY DAMAGE YOU DO TO YOUR SET.
Sony Service Manual: Host 1
How to Enter Service Menu:
[PWR OFF] - [DISP], [5], [VOL+], [PWR ON]
List of useful Information gained from the Service Menu:
Software Version:
Lamp Time:
Panel Time:
Version .01 Updated Dec 17/06 added Sony Service Manual, Started FAQ
FAQ:
A: Right Here
A: 1280x720
Software Version:
Lamp Time:
Panel Time:
